Help with temp gauge ?
Old 12-14-2004, 08:22 AM
osuidoc's Avatar
Default Help with temp gauge ?
WTF !
My water temp gauge on my 2.8Q has been acting really strange! After a cold start this am it didn't move from the resting position even after a 45 minute jaunt up the highway. I stopped to check things out and everything seemed normal in the bay. So I head down the road again and after 2 miles the needle begins to register the temp. It rises to below middle and slowly dips down and back up for about ten minutes. Then it dwops back to the resting posittion and doesn't move for the rest of my 2 hr trip!
Whats going on here?
The car didn't overheat but that may be because it is 24 deg out here in Ohio and on the highway I was clocking 75mph the whole way. No warnings came on ini the car but when I finally stopped again, I could see the antifreeze squirting into the plastic tank like it was being pumped back into the reservoir. I don't know if that is normal.
Any help is appreciated guys!
Old 12-14-2004, 08:42 AM
Junior Member
6ULDV8's Avatar
Bad coolant temp sender most likely. Yes the flow into the expansion tank is normal
Old 12-14-2004, 08:57 AM
osuidoc's Avatar
No risk of overheat then?
Old 12-14-2004, 09:15 AM
mpuzach's Avatar
Default What year is your car?
I had the same thing on my 2000 2.8q. The dealer replaced the sensor under warranty and all was well. Though I can't be 100% certain, there may have even been a recall notice on this. Either way, the cure is a simple one.
Old 12-14-2004, 09:41 AM
Junior Member
6ULDV8's Avatar
Default Get it checked out soon but there is an additional red warning
lamp that would alert you if you were to overheat. I would get it checked soon because its one of 3 things, bad temp sender (most likely), bad gauge or a thermostat sometimes sticking open. When the thermosat sticks open you can get a stone cold reading on the gauge while going down the highway, especially in cold weather. Getting it checked soon makes sense because a thermostat that is sticking open can stick closed also. Should that happen though you will get a red warning no matter what the gauge is showing. I'm like 95% its just the sender but not being there to see and feel first hand I'm covering all the bases.
Old 12-14-2004, 09:47 AM
osuidoc's Avatar
Thanks ! Appreciate the info - will get it checked today!
chicago4.2
06-24-2009 03:36 PM
osuidoc
12-14-2004 08:34 AM
RxFX101
9
09-07-2003 08:51 PM
Ken 4000
12-26-2001 07:04 PM
Benny C
01-28-2001 05:32 PM
Quick Reply: Help with temp gauge ?
