Engine Mounts - AudiWorld Forums
Engine Mounts
LinkBack Thread Tools Search this Thread
Old 07-24-2014, 07:30 PM   #1
Default Engine Mounts
Anyone have a description of how to replace the engine mounts on a 200 A6 2.8?
N_Jay is offline   Reply With Quote
Old 07-30-2014, 05:57 AM   #2
Bump . . . . .
The second part of the question:
Any harm in driving with bad (fluid leaked out) mounts other than a little extra engine vibration?
P.S. Still looking for an answer to the first part of the question.
Old 07-30-2014, 06:21 AM   #3
The left mount can be removed quite easily. Support the sub-frame, remove the engine mount bracket, and drop out the engine mount. The top nut can be a little tough to get to, but its manageable. Now the right side, thats a tough one. Its my understanding that once the front end is in the service position, you can access it then. At that point you may as well do all maintenance possible, alt, timing belt, etc.
blink is offline   Reply With Quote
Old 07-30-2014, 08:02 AM   #4
Thanks.
The Timing belt, Water pump and all was just done so I think I may wait on the mounts unless someone warns me of some problem leaking mounts causes.
Old 07-30-2014, 08:07 AM   #5
Tech Guru
4Driver4's Avatar
Dude. Please use quote and reply. It is nearly impossible to follow your threads with all your posts threaded as replies back to your original post. It's like you are only responding to yourself. Please?
4Driver4 is offline   Reply With Quote
Old 07-30-2014, 08:15 AM   #6
Quote:
DUDE . . . . Sorry, I use linear (default) display mode and find it very easy to follow.
I use quotes when there is something in the post I am directly responding to, but tend not to when it is just another post in the thread. (keeps things shorter).
I will try to remember to use them more.
EDIT:
Just tried "Hybrid" and "Threaded" display mode.
Hybrid is also easy to follow, but can't (or more correctly; didn't try hard) to figure out how to use "Threaded" as I don't see the purpose. (Maybe I can be enlightened?)
Old 07-30-2014, 12:27 PM   #7
Prospeeder's Avatar
Doesnt help that this is the most ridiculously setup forum ever. Posts should be just reply to the topic, not all the bs with replies to direct people and confusion and all the different modes the threads can be displayed. Who the hell wants that, first post first. last post last. Not to mention how absurd it is not to have editing posts standard with being a member. This has to be the ONLY forum like this. Anyway....
You can wear out the drive axles with worn out mounts. The engine moves more on acceleration and puts the axles at different angles and they wear the inner joint.
Prospeeder is offline   Reply With Quote
Old 07-30-2014, 12:54 PM   #8
Quote:
It certainly is the only one I have seen where it is an issue.
I have it set to default linear, oldest first, but every once in a while a thread shows linear newest first.
Go figger??
Anyone know how bad a problem this is?
It is a 2.8, so no one is racing around. I am looking at 6 month to a year and probably 7k to 12K miles total till I get it back to fix the rest.
Old 07-30-2014, 01:08 PM   #9
Former Vendor
Hi,
Here is a video I found on youtube that could help you with the job:
If you need the engine mounts we have two different brands available for your 2000 A6 2.8.
AutohausAZ - Engine mount
Disclaimer: Make sure to check the year and model of the vehicle before placing an order.
AutohausAZ-Mike is offline   Reply With Quote
Old 07-30-2014, 01:22 PM   #10
Airbag's Avatar
Wow we have someone from Autohaus on here ? i had no idea .. i get tonnes of stuff there for my Porsches and Audis, great guys to work with ... awesome .. but stop selling those damn Braziiian silver bosch igntion coils for 911s .. they are TERRBLE .. i had a paperweight after an hour lol
Airbag is online now   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 11 12-15-2016 05:16 PM
Audi Other FS: 2007 Audi RS4 black/black CCW ilikeit Vehicles For Sale 2 01-09-2016 10:24 AM
FS: 2007 Audi RS4 black/black CCW ilikeit Pacific Northwest Discussion 1 11-20-2015 07:57 AM
When to replace shocks and struts - Wobble at 20mph/40mph ZPA117 A4 (B8 Platform) Discussion 4 09-08-2015 12:55 PM
Audi Other Allroad Audi A6 C5 4B Shock Mount - brand new, unused Genuine Audi 4Z7698507 change2E85 Parts For Sale 0 09-05-2015 10:07 AM
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
What's your question?
Send
