Engine Mounts
Old 07-30-2014, 04:24 PM
  #11
blink's Avatar
Bad mounts will wear your inner axles. I ended up replacing both of mine. The right inner was going enough to give me a vibe on deceleration.
Old 07-30-2014, 06:19 PM
  #12
N_Jay's Avatar
Originally Posted by Airbag
. . . . but stop selling those damn Braziiian silver bosch igntion coils for 911s .. they are TERRBLE .. i had a paperweight after an hour lol
They are not for 911's.
They are for VWs and 914s so they can "Claim" they have 911 parts!
Old 07-30-2014, 06:20 PM
  #13
N_Jay's Avatar
How long were your mounts bad?
Now many miles when you have the problem?
Old 07-31-2014, 03:47 AM
  #14
Airbag's Avatar
" service position" should not intimidated anyone here. It is really quite simple and does not take that long.
I put mine into service position and put it back just to check some wiring on a fan. About an hour total. Don't feel like it something that should stop you.
The only "service position" that you should be worried about is the one your dealer will put you in.
Old 07-31-2014, 03:56 AM
  #15
Airbag's Avatar
Originally Posted by 4Driver4
Dude. Please use quote and reply. It is nearly impossible to follow your threads with all your posts threaded as replies back to your original post. It's like you are only responding to yourself. Please?
with all due respect, you are the only one that ever has issues with this and constantly comments on it. i just dont see the logic in everyone else changing how they do things and making threads 4 times as long to keep it organized for you.
have you co sidered changing how YOU view the forums ? then all the rest of us wont have to change how we do things and thread can remain compact and precise. i find it very very easy to follow without the constantly irritating requoting.
my 2 c
just a suggestion.
Old 07-31-2014, 05:26 AM
  #16
blink's Avatar
I'm unsure how long they were bad. I replaced both tranny mounts, which was very easy, and the left side motor mount. The tranny mounts looked like they were in almost new condition, once i pulled them out, they were destroyed. On the engine mount, the metal around the lower stud was broken out. Also, I would recommend replacing the front rubber "snub" mount.
Old 07-31-2014, 05:43 AM
  #17
N_Jay's Avatar
Did you find them bad during an inspection, or were there symptoms?
The car drive and idles smoothly. I don't notice any of the symptoms I would expect from bad mounts (hence why I am leaning towards waiting).
I would guess that when I do them, I will just do them all.
"Once and Done" since it made it to 125K with the originals and is not going to 250K (at least with me)
Old 07-31-2014, 05:01 PM
  #18
Tech Guru
4Driver4's Avatar
Originally Posted by N_Jay
(Maybe I can be enlightened?)
It's more of a historical issue on this forum. In threaded form, it isn't as important that threads stay on topic. This forum has been historically loosely moderated, which as worked. One of the reasons it worked well was that threads could diverge without taking away from the core topic. For instance, someone viewing this thread could just ignore this "side conversation" and force on the parts of the "tree" that were relevant or interesting. Anyone reading this in threaded mode will have to scroll through a bunch of posts between your post and my response to follow our conversation. Or worse yet, they will have to scroll through our sidebar to stay with the meat of the topic.
Contrast that with miata.net, which is very tightly moderated. Off-topic banter like this would not be tolerated since it dilutes the thread. On that forum, I use linear mode.
The root cause of the problems here is a lack of flexibility in vBulletin.
Old 07-31-2014, 05:02 PM
  #19
blink's Avatar
I really had no symptoms. After replacing my axles, i just wanted a little extra solidity. My front snub was visibly destroyed. It was the easiest replacement.
jjm82
12-12-2008 12:31 PM
a4 4snow
11-16-2005 01:35 PM
mattd860
12v V6 Discussion
04-15-2005 08:56 AM
1.8TForMe
09-18-2004 11:11 AM
Quick Reply: Engine Mounts
