2002 A6 3L Trans went @ 94k...what do i do?
Old 05-12-2009, 04:54 AM
New Member
mchalo2005's Avatar
Default 2002 A6 3L Trans went @ 94k...what do i do?
I purchased it for 7200 with a set of new pirelli snow tires in february at 90k and now the trans is going to be more than 3000 to fix...what do i do? PLease HELP!
Old 05-12-2009, 05:24 AM
lastls1's Avatar
Default You could try a fluid/filter change..not a flush
Flushing an Audi transmission is not recommended. Make sure the correct fluid is used and it's done by someone who knows what they are doing. Slipping?? Depending on how bad the problem is could just be the TC. Not a common problem for a 3.0L. Not enough power to stress the trans. $#!+ happens.....
Old 05-12-2009, 05:45 AM
Tech Guru
4Driver4's Avatar
What is the issue with the trans? Codes? Description of problem?
Old 05-12-2009, 06:18 AM
LadroAudiA6's Avatar
4Driver4 I do tech support for a huge company and I also find it ammusing when someone just sends me an email or opens a ticket saying "I cant receive emails" LOL
"Could you please be more specific perhaps? is your device even turned on"
Same thing applies to car's diagnosis the more details the better no?
Going back to OP if it's slipping I would do an oil/filter first, cover the basic stuff and then try to pull codes OBDII at minimum if you have VAG-COM even better.
And a better description of the problem; where did you get the $3500 estimate to fix the trans? What are they doing to it?
Man I feel for you; life comes at you fast sometimes.
mhale
11-04-2017 05:50 PM
paw7889
01-30-2014 06:59 PM
rush1
01-20-2009 04:55 AM
luckyxie
10-23-2006 10:57 AM
hall42
08-15-2002 11:35 AM
Quick Reply: 2002 A6 3L Trans went @ 94k...what do i do?
