error code p1857 - AudiWorld Forums
error code p1857
Old 12-18-2009, 10:25 AM   #1
Default error code p1857
hello all, this 98 a6 had some overheating ussues so replaced all the bs including timing belt, water pump rollers ,,etc..... a few times before i did the work it misired and would barley move and then it would run fine. did all the work and it's doing the same thing but will not run correctly at all. misfires , won't idle and won't go over twenty and the exhaust is blue-ish.
i've read people getting the p1857 code after battery disconnect (which iT was before and during the recent work). i've also read that somehow a bad MAF sensor could be to blame and throws this code. can anyone confirm this? i just can't contribute the misfire to f'n up the timing job because wouldn't i get error codes related to timing? the only code that i'm getting is the
p1857 and the car does not run any different with the MAF sensor plugged in or out. I took it out and cleaned it and it's dated the year of the car 1998 a-6 2.8 qttr
any thoughts on my dilema?
thanks......
audifield1 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Moody Turbo must be time of the month ;) Aman Singh Parhar A8 / S8 (D3 Platform) Discussion 7 11-29-2016 06:03 AM
UPGRADED TAIL LIGHTS tmac2015 A8 / S8 (D3 Platform) Discussion 3 09-20-2015 05:29 PM
Turn Signal Switch Problems Kongen A4 (B8 Platform) Discussion 1 09-17-2015 01:23 PM
Anyone know what might be causing this fault? mdkv5 A6 (C7 Platform) Discussion 7 09-16-2015 02:09 AM
No Start, Need Codes Diagnosis eggsngrits A8 / S8 (D3 Platform) Discussion 0 09-05-2015 11:22 AM
Tags
1998, 1999, 200, 27, a4, a6, allroad, audi, code, codes, error, fault, p1857, quattro, vag
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
