Fuse box question: switched and unswitched? - AudiWorld Forums
Old 09-16-2005, 10:30 AM   #1
Default Fuse box question: switched and unswitched?
I recently added some audio equipment and tapped into the fuse box for power (using Littlefuse Add-A-Circuit). I'd like all the devices (4 in all) to be connected to switched power. To make it more interesting the 4 devices need to be somewhat spaced out because one add-a-circuit device when used covers the fuses above and below.
Does anyone have documentation on which are switched and which are unswitched? All the manual shows is the fuse # and what it's used for. Most I can guess on (i.e. I know the heated steering wheel is switched) but others I'm unsure of. I'd rather not plug into all 44 and find out by trial and error.
Thanks for helping!
rwish is offline   Reply With Quote
Old 09-16-2005, 10:44 AM   #2
Egil A64.2s - S6's Avatar
Default Probably your best bet would be the cigarett lighter
It should have sufficeint amperage for your needs
Egil A64.2s - S6 is offline   Reply With Quote
Old 09-16-2005, 10:56 AM   #3
Default Forget the fusebox... use the power taps under your dash...
<center><img src="http://pictureposter.audiworld.com/59076/fusebox20wiring.jpg"></center><p>the yellow "75X" is what you want. Just be sure to have the proper fuses in line to your equipment, which you probably already have.
Picture credit: TeddyBGame
NSX JR is offline   Reply With Quote
Old 09-16-2005, 10:41 PM   #4
Default Re: Forget the fusebox... use the power taps under your dash...
Even better but be careful to disconnect the power from the battery before you remove these cables as a short would not be a pretty picture!
Also have your radio codes handy ;-)
Thread Thread Starter Forum Replies Last Post
PARTING OUT 2002 A4 B6 1.8T Cmmartin23 Parts For Sale 26 08-23-2016 05:44 PM
A8 W12 RSE PROBLEMS tmac2015 Audio, Video and Security Discussion 3 01-22-2016 09:14 AM
The Daily Build..My S6, the story and the questions vwleadfoot Audi Original "S" Cars 4 12-24-2015 07:07 AM
Tiptronic irenesbob A6 (C7 Platform) Discussion 11 09-18-2015 02:57 PM
Q7 Fuse questi bagsformom Q7 Discussion 1 09-09-2015 05:34 PM
Tags
2005, 75x, a5, adding, audi, box, fuse, fused, nsx, panal, panel, power, s60r, switched, tapping, unswitched
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
