Hazard lights come on
Hi Guys,
New to this site. I have a 2002 Audi A6 that Im am having trouble with.
The hazard lights comes on twice the speed while driving down the road. Seems like the only way to shut it off is to shut car off and hit the lock and unlock on the key fob. Not sure if it is a problem with the factory alarm or key fob?
Is there a way to disable the fob? or factory alarm?
Any Idea what could be the problem?
Any help greatly appreciated.
Sounds like the "Get the hell out of my way" option, I wonder what PR code that is........just kidding.
Sounds like a job for VCDS/Vagcom, it's the only way to rule out alarm issues via module inputs to determine if the dash mount hazard/flasher switch module is crapping out too.
They ramdomly come on and blink twice the speed. If I shut the car off the 4 way flasher stays on solid. I would have to lock/unlock key fob then its back to normal.
I had the left/right signals randomly work (when turned on by steering column switch) and after digging, pulled the flasher module and re-soldered / heated all the joints with a little solder flux applied. Wherever that loose contact was, it is gone and over 3 years still no issues. YMMV.
I thought of module or hazard but seems more like has something to do with fob/alarm. I spoke with previous owner and he mentioned it was broken into and he notice problem Seems like if I open locks with keys when I noticed problem happening. Doesnt happen all the time but problem coming on more now.
Sensor in lock mechanism maybe damage and wondering it the is avway to test or disconnect?
Thanks
Thanks
Thanks
Thanks
maxintosh
10-16-2000 11:47 AM
Sometimes alarm doesn't lock when I lock the doors and lights inside the car doesn't shut off (more)
turbovet
01-28-2000 10:39 AM
