my buddy has a 1999 2.8 wagon....his motor i think is fried...it started missing a tad, like a bad s
Old 12-15-2007, 04:21 AM
audi2.7audi's Avatar
Default my buddy has a 1999 2.8 wagon....his motor i think is fried...it started missing a tad, like a bad s
it started missing a tad, like a bad spark plug or wire. it started
missing more and more and then got progressively worse over the day.
By
the end it could barely run, sputtering and then I heard the rapping in
the
motor. coolant and oil fine.
Old 12-15-2007, 04:34 AM
Tech Guru
4Driver4's Avatar
Default J - I'll ring you back on this today. When you called we had the Miata on the dyno...
...and at $100 per hour I didn't want to stop tuning.
First step would be to pull codes and check the timing belt.
Funny how people hear a noise but continue driving until the car stops - lol
Old 12-15-2007, 05:46 AM
Just Me's Avatar
Default Sounds like a set of misfires. Hoepfulyl you didnt fy it (by running it)
I would start with things like wires and coilpacks, pull the codes (there must be dozens) and start from there.
Grant
Old 12-15-2007, 09:00 AM
Member
schwank's Avatar
I know a 99 2.8 with agood motor about to get totaled out
Old 12-15-2007, 10:19 AM
Pete K (vegasguy)'s Avatar
Default Nothings fried until you prove it with a compression and leakdown test, start with the basics
as the others have said. Pull codes, start digging.
Old 12-15-2007, 10:23 PM
WOWDee's Avatar
Sounds like the timing belt going
Old 12-16-2007, 05:25 AM
Just Me's Avatar
Default I dont believe that woudl ever be a gradual occurance.
They either snap, very rarely jump teeth (which i supposed could do this) or just soldier on. But I'm open to learning - what are you thinking....?
Grant
Old 12-16-2007, 06:53 AM
WOWDee's Avatar
Default Once 1 tooth is chewed off ...it will continue chewing teeth ...therefore>
causing the belt to loose more and more of it's TDC positioning until finally it won't start at all or .....like you say chews completely thru the belt or it snaps .....Usually these types of failures are never seen as it happens so quickly under normal driving conditions ....under load ...however, if yu are just at idle and minimal load when it starts to go ...it could take longer and you smay experience what the above person is experiencing ... infrequent ...amybe ...but not impossible.
Old 12-16-2007, 12:22 PM
Just Me's Avatar
Default Have you ever seen it?
I get the theory. And Heisenberg says there'
s a real possibility the whole belt's elsewhere anyway. But i have witnessed neither.
Grant
Old 12-16-2007, 12:45 PM
WOWDee's Avatar
On a Single overhead Cam ...yeh ... but not double
OzzyLime
60
04-25-2011 03:48 PM
AudiNew2me
30v V6 Discussion
17
02-08-2008 12:13 PM
Beyondhelpin
30v V6 Discussion
11
11-02-2007 05:32 PM
QCRAZY
Performance and Tuning
07-20-2003 11:53 AM
Quick Reply: my buddy has a 1999 2.8 wagon....his motor i think is fried...it started missing a tad, like a bad s
