Heater Core replacement
Hard. If the Audi dealer charges 10 hours labor to do the job it's not easy. Just look up on YouTube for audi heater core replacement. It's basically the same for an A4 or A6.
Is your heater core leaking or are you not getting any heat out of the system?
If you aren't getting any heating than I would eliminate the climate controller and a plugged up core first.
If the core is leaking you have no choice but to replace it.
Agreed. 10 hours seems long.
This youtube video shows you that it is not that difficult or time consuming at all:
2001Audi A6 2.7T Quattro Heater Core replacement - YouTube
This is easy enough you should be able to do it.
WOW! Makes buying a car with a bad heater core look attractive.
However the other YouTube shows bad lines where they go through the fire wall, so if these tubes are bad are you screwed?
Check the Bentley manual.
I have a 1999 A6 and the heater core is much easier to access than it was for my 2000 Passat (which is essentially an A4). For the B5 A4/Passat, you needed to remove the entire dashboard, including evacuating the AC to disconnect it and seal the lines. (We didn't do that; I just flushed (and flushed and flushed) the core and the radiator. After I got rid of the previous owner's Stopleak, I had heat but the radiator leaked.)
Stubborn, but Happy
Audi allroad
07-24-2016 11:30 AM
jc1113
06-23-2016 10:00 AM
gmab
06-03-2016 11:28 AM
Slinky
11-05-2002 03:06 PM
