Hedlight projector/adjuster connection loose (?)
I have non-auto leveling headlights (European DEPO supplied by Audi dealership, with height adjustment motor). I just pulled the headlights to do some work, and noticed the common projector bracket (?) (the one the adjustment screws are fixed to, not the outer reflector) - is loose. By this I mean, at the outer adjustment point (towards wing), the bracket assembly can move alot on one, and alot plus in/out n the other.
The black part seen here (red), wich goes towards the back housing and adjuster screw, is moving X/Y on one lamp, and X/Y/Z on the other - causing the lights to wobble at this point. The inner (towards grille) adjustment point and motor point seems fairly tight. Its connection to the white plastic of the projector bracket seems tight. Is something broken here, or is there a rejoinable connection here that has come loose?
Joe01S4
9
10-17-2007 07:54 AM
DARKiGOD
10-18-2005 05:58 AM
channelv
07-25-2001 04:45 PM
