HID-D2S low-beam headlight bulb change - AudiWorld Forums
Old 11-21-2010, 08:40 AM   #1
Default HID-D2S low-beam headlight bulb change
Hi, I am new to the forum, so forgive me if this question has been asked before. I couldn't find a thread on it.
After searching the web, I found that my 2001 A6 needs an HID-D2S bulb. The dealer wants about $300, so I am looking for a cheaper source.
A couple of questions. - 1. Does anybody have a reliable source for a good price on these bulbs (preferably in Canada), or know who has the best price on these bulbs?
and 2. How do you put one in? Is it easy? Straighforward? Anything to watch out for?
Any help would be appreciated. Thanks.
Wilket is offline   Reply With Quote
Old 11-21-2010, 10:06 AM   #2
bigdadi's Avatar
bigdadi is offline   Reply With Quote
Old 11-21-2010, 10:16 AM   #3
SloopJohnB@mac.com's Avatar
Relatively easy to do, not as easy as halogen, but quite similar. Worst problem is getting access to the bulb on the passenger side, but really all you have to do is flip the wire bails out of the way and winkle the black plastic cover out of the way. Then disconnect the bulb connector, rotate the outer ring around the bulb/holder CCW and out comes the bulb.
I recommend pulling the bulb and getting the specific part number of the phillips bulb (or get the p/n off the bulb at the dealer). There are probably 10 different p/n for D2S bulbs, all with different bulb temperature/colors...I happen to like the <5K bulb temps, don't like bluish light, doesn't light the road for me, YMMV.
Once you get the phillips p/n, or osram, or whatever, google it and go for lowest price.
OTOH, I've also purchased good bulbs from:
http://store.candlepower.com/d2sbulbs1.html
SloopJohnB@mac.com is offline   Reply With Quote
Old 11-21-2010, 01:10 PM   #4
Thanks SloopJohn,
I did google HID-D2S and was confused about the numbers after the bulb type. 4000, 5000, 8000?
Any idea where I can find the info, or is my friendly parts manager at the local dealer the place to go?
And it is the driver's side bulb that is out. I hope that you are saying it is easier than the passenger side.
2001 A6Q 2.7L
Old 11-21-2010, 01:54 PM   #5
Quote:
Originally Posted by Wilket View Post
Thanks SloopJohn,
2001 A6Q 2.7L
if you buy oem d2s bulbs they will be 4300k
Johann2.7t is offline   Reply With Quote
Old 11-22-2010, 02:50 AM   #6
Quote:
Thanks for everybody's help, and the other posts with lots of good info.
Turns out I don't have HID's, just halogen, so it makes more sense that one blew. And I checked the fuse just to be sure. (after I found my owner's manual) Fuse is OK. A friend of mine has a 2000 A6, and he has the HID's - I got confused as to which car had them.
However, on the left side, the remote start is in the way and makes it really difficult, if not impossible to remove the plastic cover. I will have to try removing the headlamp assembly, and go from there. I saw a DIY on another thread about that.
It looks fairly straigtforward - release clips on moulding - and then look for the screws that hold it in.
Any tips or pics appreciated.
Old 11-22-2010, 07:19 AM   #7
bigdadi's Avatar
Driver side :
After loosened the plastic cover, almost all people try to LIFT IT UP, and it's hard to do that.
I have success (no need to remove anything) to move the headlight plastic cover by push it down a little, wiggle it to the engine side, then turn one of its end facing upward. You can now slide the plastic cover out just like that.
Remember the way you just did and do the reverse after new bulb replaced.
Thread Thread Starter Forum Replies Last Post
Q7 Headlight Question davidbod Q7 Discussion 2 09-14-2015 04:06 AM
:: ECS Tuning :: B6/B7 S4 Ziza LED Lighting Collection ECS Tuning-Audi S4 (B6 & B7 Platforms) Discussion 0 09-10-2015 02:14 PM
:: ECS Tuning :: B6 A4 Ziza LED Lighting Collection ECS Tuning-Audi A4 (B6 Platform) Discussion 0 09-10-2015 01:39 PM
How to remove 1156 DRL bulbs A8 D3 ? Florida8L A8 / S8 (D3 Platform) Discussion 0 09-07-2015 04:36 PM
How to remove 1156 DRL bulbs A8 D3 ? Florida8L A8 / S8 (D3 Platform) Discussion 0 09-07-2015 06:22 AM
Tags
2001, a6, allroad, audi, beam, bulb, d2s, drivers, forum, headlight, hid, low, remove, replace, replacement, side
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
