Recomemded DOT4 vs DOT 5
Old 03-10-2014, 10:27 PM
pyrobionic's Avatar
Default Recomemded DOT4 vs DOT 5
What is the real differences? Which one is better in hot/cold or does it matter? And which brand would you recommend?
Old 03-10-2014, 10:32 PM
raj99's Avatar
you should NEVER use DOT 5, since it is silicone based.
Get DOT 4 or DOT 5.1, and as long as it meets Audi specs you should be fine. Do a search of the archive and you'll get plenty of opinions: Valvoline, Pentosin, Castrol...
The actual make of the fluid doesn't make a huge difference, but whatever you do, don't buy DOT 5.
FWIW 5.1 is primarily for racing...I REALLY doubt you'll need that. Stick with DOT 4 and you'll be fine.
But you should SERIOUSLY start learn to use the Search function...since your questions are things that have been covered EXTENSIVELY.
Old 03-11-2014, 02:59 AM
Tech Guru
4Driver4's Avatar
Originally Posted by raj99
you should NEVER use DOT 5, since it is silicone based.<snip>
Agreed. I run NAPA heavy duty DOT 4 in everything but the track car.
Old 03-11-2014, 03:05 AM
uberwgn's Avatar
Depending upon the vintage of the vehilce, Pyro, there's even a different standard for newer cars. They're supposed to run one of the low-vis fluids:
Pentosin seems to be the common one. There are a few others.
File Type: jpg
File Type: jpg
Old 03-11-2014, 04:10 AM
jseklund's Avatar
I've always used the Valvoline Synthetic Dot 4 and I'm sure anything like that will do. You are usually talking $2 or less more to get the best Dot 4 the store caries, since you will need 1 container in most situation, so I just go with that. Never thought to look at the Napa stuff, will have to check it out.
Old 03-11-2014, 09:49 AM
pyrobionic's Avatar
The search function does NOT function lol most the time it does decide to load its all ads and spam and has nothing to do with what I search.
Old 03-11-2014, 09:55 AM
pyrobionic's Avatar
That's what Im running now. I'm thinking about going to Ravenol I use a lot of parts from blau but I've never used there fluids but supossedly it's all OEM certified. Up in my next changes I may convert to ravenol fluids and see how well they really are.
Old 03-11-2014, 11:24 AM
jcman's Avatar
Please PM Kris Hansen about your problem so you can gain full use of the forum, no one has ever mentioned a problem searching the forums or STF for info.
Thes6isWicked
S4 (B8 Platform) Discussion
05-16-2014 05:45 AM
tony7314
S6 (C7 Platform) Discussion
14
02-26-2013 02:57 PM
Matt Devo
Brakes Discussion
07-26-2006 10:02 AM
cpayne
04-23-2001 08:03 PM
Quick Reply: Recomemded DOT4 vs DOT 5
