How to disable alarm system
Old 08-05-2008, 09:33 AM
doobiesdaddy's Avatar
Default How to disable alarm system
About 3 weeks ago my alarm started going off randomly. I took it to my indy and they told me there was a fault in the trunk switch and the left drivers door switch. They replaced the switches and the problem was fixed. or so I thought. Now the alarm is going crazy again. I took it back to the indy and no faults. the interior monitor is reading ok. I am at the end of my rope. does anyone know how I can just disable the alarm. As long as the car locks I am fine with no beep.beep.beep.beep. No body looks or helps when it sounds anyway, right?
Old 08-05-2008, 09:40 AM
Member
audikillsbmw's Avatar
Normally I'd say you should post this on your home forum, but you do have a C5.
Old 08-05-2008, 09:42 AM
Fear the Miata!
Press's Avatar
any feedback from the ar forum?
Old 08-05-2008, 09:50 AM
Tech Guru
4Driver4's Avatar
Fix it.
Old 08-05-2008, 10:03 AM
nothing broken as per dealer and indy;allroad forum could not help my problem
Old 08-05-2008, 10:04 AM
Re: no help from allroad forum
Old 08-05-2008, 10:05 AM
Re: allroad is nothing mroe than a tricked out S4/A6
Old 08-05-2008, 10:26 AM
Li3ny's Avatar
Default No issues starting? Could it be your battery...
This is common in aftermarket systems, if the voltage gets to low it trips the alarm. I know Nissans do it as well. If there's a drastic change in voltage somehow, that could do it. Dome light, phone charger, faulty audio equipment.... I know our cars log "low voltage" but that's only while the car is running to monitor the alt. I don't think it monitors w/ the car off....someone please correct me if I'm wrong.
Old 08-05-2008, 10:29 AM
Battery is 6 mo. new and it is the factory installed alarm system
Old 08-05-2008, 10:30 AM
is there a fuse or relay that I can pull to disable the alarm permanently?
Quick Reply: How to disable alarm system
