Fuel Mixture Issues
Old 02-10-2004, 09:40 AM
New Member
UtahA6's Avatar
Default Fuel Mixture Issues
I have a 98 A6 with 100,000 miles on it. It just starting acting funny last week and was wondering if anyone has ever seen anything like it. It seems to be missing in the 1000-2000 RPM range, it may be at higher RPMs, it is just harder to feel. The odd thing is that when I fill up the fuel tank, it takes 10+ second cranking to turn the car over. It helps if I open the throttle half way. The starting issue only happens at the gas pump.
Any Ideas?
Old 02-10-2004, 09:46 AM
AUJ
AUJ's Avatar
VAG-COM the O2 sensors as a secondary causation.
Old 02-10-2004, 09:51 AM
AudiWorld Uber User
April's Avatar
Default As AUJ says, check the 02 sensors. Also check fuel pressure.
You may have a clogged filter or clogged/bad pump. Also check the anti-drain-back valve in the fuel system. If it allows pressure to bleed out of the rail while turned off, it will take a little while for it build back up. That doesn't solve the ongoing missing, but it is often the reason for extended cranking on older cars.
How are the spark plugs and wires? A marginal connection down around the coil packs can result in rough running and hard starting.
Old 02-10-2004, 10:05 AM
Member
OPTIMUS PRlME's Avatar
man...april is a walking talking repair manual for cars...and i thought i was car savvy..psshh
Old 02-10-2004, 10:40 AM
Hy Octane's Avatar
Default How old are your plugs? Carbon buildup on valves and injectors..
soulds like you need some deposit remover and a good blow out on the highways..
Y888
12-17-2015 11:57 AM
kuwe34
Audi 100 / A6 (C4 Platform)
01-12-2010 06:37 AM
highlander69
10-21-2008 08:38 AM
S90RTRRO
12
09-28-2007 04:01 PM
saunders
12-26-2002 07:11 PM
Quick Reply: Fuel Mixture Issues
