How to remove lower crankcase breather hose?
Hi guys, new member here...have been using site for a while and have always found what i needed searching around but today no luck and looking for a DIY or guidance on how to remove the very end connector of the lower crankcase breather hose that connects to the block? (2002 A6 3.0)
I broke the hose when removing the whole pcv and spider hose assembly and see no easy way to get the snap on fitting off.
Thanks in advance
Thanks in advance
Well finally managed to get acces by disconnecting a couple hoses and carefully snapping off the clips holding the tube to the crankcase connection. Then it's a simple matter of getting your hand down there ( or your wife's!)...either way major PITA to do. Only thing worse, is the cost the dealership charges for plastic! Now on to fixing some broken vacuum lines...
Audiheavy
09-20-2022 07:42 AM
MarkW
05-13-2006 12:47 PM
