how to replace right rear abs speed sensor
Old 11-29-2010, 08:03 AM
mswanson65's Avatar
Default how to replace right rear abs speed sensor
Hi all,
My 2003 A6 4.2 has a code saying that the right rear abs speed sensor has a fault to short. I bought a new sensor on ebay and am now trying to install it. I can not figure out how to access where the sensor is plugged in. It seems to be up in the frame of the car. Can someone who has done this replacement before give me a clue on how to di it? Thanks
Old 11-29-2010, 09:36 AM
SloopJohnB@mac.com's Avatar
My Bentley says you have to remove the rear seat bench out of locking mechanism.
Apparently the connector is under the seat.
Then you push the grommet/cable through the panel.
The sensor has a retainer on it that you remove and then pry the sensor out of the wheel housing.
You use brake wheel cylinder piston lube (a grease that is compatible with brake fluid!) to lube the sensor and push it in and lock it in with the retainer.
Old 11-29-2010, 01:15 PM
mswanson65's Avatar
thanks! What does the Bentley say on removing rear seat? I have a vag but I really need to get the bentley!
Old 11-29-2010, 02:29 PM
socalclimber's Avatar
Default pull up on front of bottom seat cushion
On my 2002 4.2, I just pull up on front of bottom seat cushion. There are 2 u-shaped springs that lock seat cushion into place (no screws or nuts). You can't see them as they fit into a slot in body that is hidden under seat. Rear part of cushion slides under seat backs.
faciest
10
10-03-2023 12:49 PM
saleen351
08-21-2014 09:57 AM
Steelman93
03-16-2013 06:48 AM
Pupek
1.8T Discussion
03-16-2009 05:37 AM
Corey
05-22-2005 10:44 AM
Quick Reply: how to replace right rear abs speed sensor
