Issue with a 2000 Audi A6
Old 08-27-2016, 09:03 AM
jeffkruse's Avatar
Default Issue with a 2000 Audi A6
This is my daughters car and she said people have been telling her and she has seen this too. That some times while the car is sitting in the driveway/parking lot of her work, the lights will flash like she is locking the car even though she has not touch her keys to lock. Last night the horn went off for about 10 seconds the same time the lights went off, then horn shut off lights keep going. Any Ideas?
Old 08-27-2016, 01:21 PM
meternerd's Avatar
She forgot to turn off the motion sensor? Top button inside the drivers door jamb. Have to do that if you leave the windows open or you have a dog. I don't know if the lights flash on, but I know it alarms with the wimpy horn in the trunk.
Old 08-28-2016, 12:23 PM
jeffkruse's Avatar
not sure if this has anything to do with it either, but noticed the unlock button does not work on the key fob. The lock and open trunk do work. Any thoughts?
Old 08-28-2016, 03:00 PM
clancy's Avatar
Search for convince module malfunctions. I recall some have posted that device does these kind of things when it has gone off the reservation.
Old 08-28-2016, 03:29 PM
georgeb944's Avatar
Use VCDS to pull the codes from the alarm monitor. It might just be a malfunction of the driver door latch switch.
Old 08-28-2016, 05:22 PM
jeffkruse's Avatar
here is the scan
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
VCID: 306888EFF030F4BEED-4DD6
5 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01561 - Rear left door
59-10 - Can't Unlock - Intermittent
01562 - Rear right door
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 A
Component: Sitzmemory D05
VCID: 2B529F83D9169766D8-4A9C
No fault code found.
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
VCID: 26446EB7C2F4AA0E07-51D0
2 Faults Found:
01349 - Alarm via Theft Warning System; Front
35-00 - -
01350 - Alarm via Theft Warning System; Rear
35-00 - -
Old 08-29-2016, 09:05 AM
georgeb944's Avatar
Reset the codes, and when it happens again, pull the new codes and that is your culprit.
You could also disconnect the interior monitoring module, which is under the rear seat, IIRC.
Old 08-29-2016, 09:15 AM
SloopJohnB@mac.com's Avatar
Default sure sounds like locking module (convenience module).
Originally Posted by jeffkruse
here is the scan
Coding: 15885
Shop #: WSC 02325
5 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00101
Shop #: WSC 02325
2 Faults Found:
35-00 - -
35-00 - -
But I go along with clearing codes and catching the next one that pops up.
Old 08-29-2016, 05:06 PM
Prospeeder's Avatar
If that door latch trigger keeps coming back, then it needs a new latch, or the wiring in the door jamb is broken/damaged. You should be able to go through the measure blocks and find one that says what triggered the alarm last. Save you from having to wait for it to do it again.
Old 09-05-2016, 08:09 AM
jeffkruse's Avatar
Default I cleared all the codes for central locking system(35) and......
Interior Monitoring(45)drove for a few days. Ran a scan and got these codes back again. Not to concerned with the locking as it might be battery in fob or fob itself. More concerned with the interior monitoring because it will sometimes out of nowhere the horn and lights will starting flashing. It ran down her battery. Ran output test for locks and everything passed fine including the unlock of all doors, that is why I thought it might be batteries or fob. But for some reason it will not let me run output test for interior monitoring. I just set the sensitivity to 50 instead of 100. Any other suggestions would be appreciated. Thanks
Coding: 15885
Shop #: WSC 02325
3 Faults Found:
35-00 - -
VCID: 2B529F83D9169766D8-4A3A
Coding: 00101
Shop #: WSC 02325
1 Fault Found:
35-00 - -
Quick Reply: Issue with a 2000 Audi A6
