Leaking 5hp24a
Leaking 5hp24a
Hey Everyone,
I have a 2001 A6 4.2 with a 5hp24a transmission that is leaking. Ive removed the part indicated by the yellow circle and replaced the gasket indicated by the green line. The transmission fluid is leaking by the red arrow from where the bolts connect to the transmission. I know that it is not the differential gear fluid because I replaced that and the color is clear/yellowish. The Trans fluid is red and leaks running down the side of the transmission and dripping on the cats.
Any help is appreciated
5hp24a
5hp24a
Perhaps you should consider replacing the gasket at the red arrow?
Hey Everyone,
5hp24a
5hp24a
Step one in rebuilding the trans is removing the transfer case…the gasket you want to replace is right there in the picture.
Yeah that's my next step. I replaced the one in the picture that you posted from tomboynton.com. Thats the one I thought was the problem but nope... Oh well Ill try again
AIRFORCE3
12-12-2000 08:38 AM
