Locked passenger door
#11
To the OP…look at the front door on the drivers side with the rear door open. Eyeball that U-shaped latch holder while you close the front door and you can see where it is. It's in a similar spot on the passenger side front door.
It might be easier to get to if you take off the rear door.
BTW, it's called a striker plate. #7 on the diagram.
Striker. STRIKER PLATE for 2002 Audi. #8Z0837033A
#12
#13
the door is opened
You can't get to the screws when the door closed. This is how i did it. I entered through the driver's door and forced a flat screw driver on the side of the locking **** on the top of the door panel to pry out the black housing so I could have enough space for me to insert a wire with a small hook at the end. I kept sinking and pulling the wire and managed to pull on the mechanism that opened the door. This was a combination of brains and luck. But guys I must admit, audi's security system is the safest. We made the right choice.
The interior door card is very easy to remove: Two screws, one each end of the door at the top, with the door open. Underneath the front end of the armrest/door pull there is a small hole - poke a flat screwdriver up into this hole & 'fish' around to unclip the switch panel at the front end then pull it out & disconnect the plugs. Lift the whole panel up & away from the door (by a couple of inches only) & then disengage the hook of the lock cable from the silver handle. Hope this helps. Please, please please, don't do any cutting - it won't get you anywhere & you will ruin a beautiful panel.
Cmmartin23
26
08-23-2016 04:44 PM
4ringsinutah
06-16-2016 03:28 PM
danfil
09-19-2015 06:32 PM
