Odd battery failure
Old 07-18-2014, 11:00 AM
johnkk's Avatar
Default Odd battery failure
Noticed slightly slower cranking and occasionally the engine would hiccup at very light throttle. Ran a vcds scan and found intermittent knock sensor signal too high and intermittent voltage too low codes. Never seen those before.
Checked the battery terminals and the negative post was slightly crusty, so I dug out my terminal cleaning brush device and cleaned the posts and cables.
When I pulled the cables, I noticed a split/hole in the top of the battery near the negative post. The flat surface was deformed around the hole. Hmmmm. Almost looked melted. I guess that the electrolyte fluid level was getting low and perhaps a cell was starting to go bad or developed an intermittent short.
I replaced the battery and cranking back to normal. Codes have not returned. Bad battery was an Audi replacement about 4 years old.
Anybody ever see a battery develop a hole?
Old 07-18-2014, 12:37 PM
Airbag's Avatar
im sure this one did !
Old 07-18-2014, 06:16 PM
SloopJohnB@mac.com's Avatar
Yes. You're actually quite lucky because such holes often vent H2 and O2…not a good mixture to meet a spark such as might occur with removing a battery terminal to clean the post and terminal!
Old 07-19-2014, 06:51 AM
johnkk's Avatar
Lighting a match to check electrolyte level.
Old 07-19-2014, 07:50 PM
Redd's Avatar
Battery cases these days are usually molded and welded thermoplastics, so yes, they can certainly split on welds, or melt from internal heat from a number of conditions and defects.
These defects can often be caught early when there is a voltmeter in the car, but car makers don't want us to bother our heads with these highly technical matters, like counting to fourteen.
The odds are that you will never have another defective battery in your driving years though. That's good news.
Old 08-02-2014, 01:29 PM
Priceless
dangerdred
15
07-22-2018 07:36 AM
am_ver
10-24-2016 02:49 PM
awdinut
15
09-18-2011 04:46 PM
tauruspower
Telematics Discussion
11-23-2010 02:31 AM
back2black
05-16-2003 05:18 AM
Quick Reply: Odd battery failure
