New MAF, same problem.
Hey all,
Recently picked up a rather clean 2003 A6 2.7T 6spd. Nice car, dealer maintained all its life. PO said it has a stage one chip, but he couldn't tell me what brand... Anyway, ran great for 400 miles after I bought it, then started bucking and the ESP / CEL lights came on. Lost all boost (limp mode?) and ran poorly.
Did some digging here and all threads pointed to a bad MAF sensor. I have VCDS Ross-Tech and it reported:
18010 - Power Supply Voltage 30 P1602 - 35-10 Voltage too low, intermittent
16487 - Mass Airflow Sensor (G70) P1030 - 35-00 Signal too high
17964 - Charge Pressure Control P1556 - 35-00 Negative deviation
17551 - Load calculation cross check P1143 35 - 10 Upper limit exceeded - intermittent.
Did some research here and at Ross-Tech and it pointed to limp mode and a bad MAF. So I replaced it with the Hitachi unit, bought online at ECS. Also put in a new airbox gasket and air filter. Cleared the codes and:
Same problem, car idles like crap, never got it out of the garage. ESP light came back on (not CEL), and the:
is back, no other codes (didn't drive it it so it didn't go into limp mode?)
Anyway, did some more searching here, and it seems there might be a vacuum leak somewhere. Before I go digging around looking for a leak, is there any particular weak area I should start in?
thanks,
thanks,
Hey all,
thanks,
thanks,
PhunkFX
9
06-30-2007 07:55 AM
S4MarkS4
11-09-2005 04:52 PM
DrizzTT
10-01-2004 04:46 AM
ivansis
09-19-2001 08:27 AM
