New o2 Sensors, Resetting ECU (limp mode?) - AudiWorld Forums
Old 07-16-2014, 11:45 AM   #1
Default New o2 Sensors, Resetting ECU (limp mode?)
Hey all,
So I just bought a C5 (A6 Avant) and I needed to replace the cats and o2 sensors. Magnaflow cats are already in and I'm replacing the o2 sensors tonight, but what method should I use to reset the ECU? There are so many on the forums, but folks are warning about the battery method because of limp mode. I actually just replaced my battery, and didn't really notice anything different? Is my car IN limp mode now? How would I know?
I don't have a vag com, and I'd prefer not to go back to the shop, but will the battery ecu reset clear the settings/cel well enough?
Thanks all!
gtiwithav8 is offline   Reply With Quote
Old 07-16-2014, 11:48 AM   #2
Also, I just read that it is easier just to disconnect the ECU. Seems the ECU is just as easy to get at as the battery was, so would this be a better method?
Old 07-18-2014, 02:32 PM   #3
Okay, new o2 sensors are in. Tried resetting ECU by disconnecting battery for a couple of hours, but this didn't seem to reset the ECU... CEL still on (which might just mean new o2 sensors didn't fix the problem), but the throttle body did not go through its realignment. So I'm wondering if the ECU reset at all? Is there another method I should try to reset the ECU by?
Old 07-18-2014, 03:21 PM   #4
As far as I know, those codes are stored, so disconnecting the battery won't clear anything.
You need to clear the codes with VCDS or a scan tool.
seishuku is offline   Reply With Quote
Old 07-18-2014, 03:28 PM   #5
Thanks for the response. If I want to buy my own, is this the only option?
http://store.ross-tech.com/shop/VCKII.html
Not sure if it is worth the investment/how often I'll use the thing.
Old 07-18-2014, 04:35 PM   #6
Get a $10 eBay cable and use VCDS-lite, it'll do what you need.
I can't justify the $250 cost either, even if it is worth it really.
Old 07-21-2014, 08:28 AM   #7
Airbag's Avatar
dont you havea buddy with an OBD2 tool ? if all you want to do is read and reset generic codes any OBD2 reader will do that ..
well at least 90 %
Airbag is offline   Reply With Quote
Old 07-21-2014, 09:22 AM   #8
Quote:
well at least 90 %
Yep, that did it! Thanks all! If anyone is reading this threat in the future, I would really recommend the little $12 blutooth obd2 reader.
Old 07-21-2014, 09:30 AM   #9
Airbag's Avatar
link ?
do you read it on your phone with an app or something ?
Old 07-28-2014, 09:20 AM   #10
The one I used was the Elm327 I believe, and yeah you can use your phone as the device has blutooth. Pretty handy!
Thread Thread Starter Forum Replies Last Post
Audi A4 Limp mode ? 1.8T rowl3y A4 Cabriolet (B6 Platform) Discussion 1 03-09-2016 04:06 PM
Just had service on 2014 S6. Can anyone verify I have latest ECU/TCU software? Dr Chill S6 (C7 Platform) Discussion 1 11-05-2015 10:25 PM
Throttle cut out saga urojohn S4 (B8 Platform) Discussion 2 11-01-2015 05:02 PM
No Start, Need Codes Diagnosis eggsngrits A8 / S8 (D3 Platform) Discussion 0 09-05-2015 11:22 AM
Limp Mode 2.7 Tip cameltrophyallroad Audi allroad 4 09-04-2015 06:40 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
