Not the coil
Old 10-21-2016, 06:29 AM
logicbeats's Avatar
Default Not the coil
So I just put the intake manifold back on and replaced one of the vacuum hoses. I cleaned the throttle body as well. After assembly, the engine is running rough. I was getting a 301 code with a randomly flashing engine light. I replaced the coil. No change. When I first start the car, no problem. When the engine rpms come down, that's when the flashing engine light starts. Thanks in advance for any advice 02 A6 3.0
Old 10-21-2016, 10:25 AM
SloopJohnB@mac.com's Avatar
Default It's likely misfire on #1 cylinder. P0301?
Try moving the plug to another cylinder and see if the misfire moves. If it does, it's the plug. It could also be a leaking intake manifold gasket or some other hose got hosed (pun intended) along the way.
Old 10-21-2016, 10:53 AM
logicbeats's Avatar
Perfect! Great idea.. thank you.
Old 10-21-2016, 12:50 PM
logicbeats's Avatar
Switched the spark plug. Code went to 300, 301, 304
Old 10-22-2016, 09:43 AM
rocketman4321's Avatar
Without matching the numbers to cylinders...check the driver modules mounted on the intake/air filter housing. You probably unplugged them to get at the manifold. I think P300 is a random misfire, which would be consistent with a loose connector. Each module drives the coil packs on one bank, so if the numbers match that's further evidence.
HouTex
A4 (B8 Platform) Discussion
13
11-30-2022 05:22 AM
martinz.zz
10-11-2017 10:27 AM
Ande1160
05-13-2014 06:15 AM
prodaytrader
9
10-26-2008 03:00 PM
JeffDavison
03-26-2001 04:09 PM
Quick Reply: Not the coil
