not starting after starter replacement
Car: 2000 Audi a6 quattro 4.2l V-8
My car was not starting while the engine was warm (starter not engaging or turning) so I set about replacing my starter.long story short, I was taking off the old starter and noticed the battery has not been disconnected.
I put the new starter on, reconnected the battery, and nothing.
I took both the new and old starter in to be tested. They both passed. When the old starter was reinstalled it did not work. I tested the 200A fuse between the starter and battery and t was blown. I put the new starter back in, and today put the new fuse in (it took a week to come in). My car is still not starting.
Anyone have any ideas of what to check? School is starting back soon so I need to get this done ASAP
on mine the lead wire from the ignition switch to the starter solenoid was all coroded ,, read 12v but couldnt carry enough current to fire the solenoid. stripped it back about 12 inces and connected in a new piece and bingo.
I did not notice any corosion. Tomorrow I will put my car back on the lift and strip some of the rubber off if the wire. I don't think this is the problem though as before I replaced the starter it would start while the engine was cold. Now the starter will not engage at all
Use a large screwdriver to jumper between the large cable connection on the starter to the small ignition switch wire (make sure the car is not in gear first). If the starter solenoid picks and the starter turns, then the issue is not in the starter, but most likely in the ignition switch or the wiring between the ignition switch and the starter.
Georges suggestion will work but is very feaky and somewhat scary .. just pull the small wire off and stick your meter probe in the end of the small wire . you may need an assistant.. that should go to 12v when you go to start position. the negative probe should be ground obviously
If the car will run if you start it with the jumper, you could just install a pushbutton switch until you get time to figure it out.
RUFUSDESIGN
03-20-2012 10:38 PM
