O2 Sensor Issues
#11
its bad cats, yet to ever see cat codes from an o2 sensor. Its using a very logical pattern to figure out over the course of many drive cycles if the converters are working correctly. Comparing them to the signals before the cats. It will see high fluctuation in mixture after the cats meaning the cats arnt working. The sensor cant magically crate more voltage and fluctuate, its not how they work. The cats are bad.
#12
yup those are bad cats i would think .
You can in vag com tell if they are aging O2 sensors or if the heater element is gone but those are completely different codes...
However .. if you want to try ........
if i were replacing the cats i would replace all 4 o2 sensors anyway .. in for a penny in for a pound. So if you are up to it you could repalce all 4 first and see what happens for your own peace of mind. bu i think ur gonna end up with new cats by the end ..
#13
It is expensive (as in, more expensive), but it is a good idea to replace all O2 sensors with the cat.
#14
Well, i decided to hook up my scanner again while the car was @ full operating temp and watch the live data. The live data scans and reads voltage of all O2 sensors. Being that the 2 that have been throwing the codes, bank 1 and 2. I watched those as I let the car idle and during rev's between 2500 - 4k.
Can someone tell me if these numbers sound right while is at a steady idle of 2500rpm
b1 - 0.7 - 0.1v
b2 - 0.1 - 0.08v
Now bouncing the revs between 2k - 4500, the voltage is all over the place going anywhere from 0.7 - 0.1 on bank1 and 0.7 and 0.08 on bank 2.
during idle the voltage on both banks go from 0.7 - 0.1v. From my google searching a fully functional O2 sensor should read voltage around 0.5 - 1.0v Mine never see 1v as they're bouncing around from 0.7 - 0.05v
Also to note, while revving i saw bank 2 o2 sensors go straight to 0.00v. I would think that would be bad.
I do have a video of this, but I need to get it uploaded to utube 1st.
Thanks!
b1 - 0.7 - 0.1v
b2 - 0.1 - 0.08v
Thanks!
#15
ok this is how an o2 sensor works. its creating a voltage signal out of the oxygen different on each end of the sensor. If the voltage is high up to .9 to 1.0 volt, than theres a big difference, or rich. If theres low voltage 0.1, theres not much difference, so lean. They will bounce back and forth rich lean rich lean and the ecu uses those signals to keep mixture proper. If the Cat is working, there should be very little fluctuation of voltage from the sensor. Thats how it knows its working. if the sensor is fluctuating like the front oxygen sensors, that means the cat is not working and it sets a DTC after so many drive cycles. By what your saying, the cats are bad. Stop wasting your time on the sensors themselves, there fine. Normal range is .1-.9 volts. 1.0 is like mega rich holy crap its just dumping fuel, obviously your not going to see that.
#16
although im inclined to agree that the cats are indeed the issue
#17
o2 sensors fail by getting slower and slower response untill there is no more response and it sets a no response code. Of course the heater element can fail and set a code also.
#18
just as a data point and not a recomendation : about a year ago i changed the cats . what a huge nightmare diy.
a year later one of the o2 sensors failed.. repeated pita. should have done the sensors. lesson learned.
#19
i think you have it, btu that's a pretty confusingl;y worded response.
The O2 sensor measure residual reactive oxygen to see how much is Co2 (by product of combustion). For the engineers out here, from here its a simple negative feedback loop. If the figure is too low, you have unburned HCs. Too large, its too lean. Teh mixture is adjusted accordingly.
Now, the o2 sensors are also used for a different purpose. They measure the gasses before and after the cat. If its working efficiently, the difference is large (%). If they are not, its relatively the same (%). So a small delta can means:
1. dying cat
2. higher reading from o2 sensor #2
3. low reding from 02 sensor #2
4. combination of above
Its very hard to be 100% clear.
God did it.
Grant
1. dying cat
God did it.
Grant
#20
I paste my answer from another topic liek this:
Have you find any solutiins for this?
I bought recently A6 Avant with ASG engine (4.2 V8), after 1500miles i get P0430 with every 300miles. 1st i used OBD2 reader, but today i got VCDS(VAG-COM) and there is 2 faults now:
2 Faults Found:
16814 - Catalyst System; Bank 2
P0430 - 35-00 - Efficiency Below Threshold
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst
P1176 - 35-00 - Control Limit Reached
Readiness: 0000 1001
I captured some data from O2 sensors, bank 1 sensor 2 seems to be dead, or getting lot of air..
ASG 4.2 V8 juniku O2 sensor P0430 P1176
400miles before problems started, i started to use Shell V NitroPower instead of RE95, i dont know did it have anything to do with it, but next fill-up will be RE95, i will take car to to emission tests in early next week.
2 Faults Found:
