OBD
OBD
Hi trying to access my OBD codes via my climate control. I have a 2003 a6
Heater core problems but want to check to see if my temps are set correct.What buttons do I use to activate and toggle thru the menu.
Thanks.
Thanks.
Out of curiosity, where did you hear you can access codes via the climate control?
There's a video on YouTube. Just Google on board diagnostics for Audi but mines not functioning the same way that video is I can't seem to toggle thru The menu. trying to eliminate any possibilities of something else been wrong before I replace my heater core.I really really really don't want to do it.you want have any suggestions I could use some help here.
Before you do anything check for any codes with vagcom, if no codes exist then check the temp difference between the inlet/outlet of the heater core to determine if it's clogged causing a resistance of flow, there has been many posts about restricted heater cores with a good amount of detail on diagnostics and remedies.
BTW, if you are referring to this link right out of the tech section for A4's and S4's AudiWorld Tech Articles I don't believe that this applies to the C5 newer than 02.
You can try, Good Luck!
Got it, that's why I responded with some info, facts and a direction for you to go on, so outside of that vagcom and searching the forums is all up to you.
