Oil leaking from rear output shaft seal on transfer case?
Old 09-27-2016, 11:12 AM
wrcspz's Avatar
Default Oil leaking from rear output shaft seal on transfer case?
Hi guys, just purchased a 2003 RS6 and after driving it, I seem to have a gear oil leak from the transfer case. Seems to be the output shaft for the driveshaft coming out of the transfer case. Does anyone know if this is an involved job and is it something I should be fearful of? I'll post pictures once I clean her real good!
Old 09-27-2016, 11:24 AM
snagitseven's Avatar
Been there. If you're talking about the main drive shaft, it has to be dropped using a special jig to avoid damage. Best to do both front and back shaft seals at the same time - the other one will surely start leaking soon.
Old 09-28-2016, 11:09 AM
Airbag's Avatar
I did mine no problem without any special jig.
Old 09-28-2016, 11:47 AM
the_duke's Avatar
Just be cautious with the drive shaft. Don't let it hang by the carrier bearing or the joints at either end. Also make sure you mark the position of the carrier bearing before you remove the driveshaft. I've seen drive lines damaged when people use an overhead lift and then let the shaft fall only to be caught by whatever was still connected to the car. You can easily damage the carrier bearing or the joints at either end doing that.
Old 09-28-2016, 02:41 PM
Exactly, which is why to be safe Audi specifies the repair procedure using the jig. There are workarounds but as you stated, special care must be taken to avoid damage.
Old 09-28-2016, 02:52 PM
the_duke's Avatar
I agree that the correct jig would be best. But probably not practical on a car that old. It may not even be available for purchase anymore.
Old 09-28-2016, 06:18 PM
Maybe this?
https://audi.snapon.com/SpecialTools...temid=10120008
Old 09-29-2016, 10:20 AM
the_duke's Avatar
Perfect! Not a bad price either.
tnorth
08-28-2008 05:32 AM
Khuram
02-06-2008 01:44 PM
a4avant99
10-15-2006 03:34 PM
jarosteve
09-19-2005 06:11 AM
Jim De Arras
06-04-2002 06:54 AM
Quick Reply: Oil leaking from rear output shaft seal on transfer case?
