oil pressure question
Old 11-22-2014, 03:50 PM
ake11's Avatar
Default oil pressure question
02 3.0. Im getting about 22psi at idle and about 43 at 2k rpm with the oil temp at about 190F. Is this to spec? too low? obviou8sly the higher the oil temp gets the lower the pressure gets.
anyone have any readings at fully warmed up?
thanks
Old 11-23-2014, 02:43 PM
SloopJohnB@mac.com's Avatar
Default Sounds like yours is ok.
thanks
Oil pressure switch is near the oil filter mounting plate, up and slightly left. Unscrew it and check oil pressure with known good mechanical pressure gauge.
Idle should be at least 1.5bar.
2K rpm should be at least 3.0bar
https://www.dropbox.com/s/gay6uzvait...%20PM.png?dl=0
Bentley says if pressures not obtained oil pressure relief valve or oil pump is faulty, replace oil pump.
Old 11-23-2014, 06:32 PM
ake11's Avatar
great thanks. cleaned screen on pump check pressure right on spec, no more light hopefully that was it.
thanks again
Jeffrey A Gersin
Audi A3 / S3 / RS 3
09-07-2020 05:39 PM
hdmyers
13
02-14-2009 06:44 PM
psmith
30v V6 Discussion
04-17-2006 06:37 PM
Luxus Panzer
10
07-16-2004 05:38 AM
merv
03-18-2003 07:17 AM
Quick Reply: oil pressure question
