oil pressure question
02 3.0. Im getting about 22psi at idle and about 43 at 2k rpm with the oil temp at about 190F. Is this to spec? too low? obviou8sly the higher the oil temp gets the lower the pressure gets.
anyone have any readings at fully warmed up?
thanks
thanks
Sounds like yours is ok.
Idle should be at least 1.5bar.
2K rpm should be at least 3.0bar
https://www.dropbox.com/s/gay6uzvait...%20PM.png?dl=0
Bentley says if pressures not obtained oil pressure relief valve or oil pump is faulty, replace oil pump.
Luxus Panzer
10
07-16-2004 05:38 AM
merv
03-18-2003 07:17 AM
