Oil Temp sender location = ??
#11
While I have your attention, is there a way to save your display options?? I have looked in used CP and a few other places. When I open this part of the forum it displays by thread title, and from the beginning and loads like almost 10K threads, I then sort by last post and last month (there is a third option but dont remember and not critical) I hit search and it works BUT if I go back or leave the forum it reverts to all & title.
Any idea as to how to set this??
For some reason the for sale looks to work as other forums I use.
Thanks for the help on the temp sensor, I hate a gauge not working.
Regards
Regards
#12
Well today was oil change day (as well as RF CV boot r & R) but i wanted to report back that YES it was the sender on the Pan, it was a Meyle and i did put in the Hella ( hard to go wrong with their stuff).
I appreciate the help posted and dont want to have un finished threads, all looks well also did the CV boot replacement with several tips from here, (did not disconnect inner flange) and all went pretty well. Now maybe tomorrow night I will do the motor & trans mounts and all the stuff from the PO will be done.
I did the Hawk HPS brake pads all around a few weeks ago and they feel great.
Again thanks to all and I will try to help where I can here, learning curve on the Audi A6 Avant, have lots of experience on the early P cars if anyone needs help or parts.
Regards
Regards
#13
Regards
Regards
Worst part of changing out that sensor is an oil pan leak later...LOL.
I dropped the oil pan and there was some thin sludge that wouldn't drain even hot. Oil would immediately change color on oil/filter change. After cleaning pan (100+K) the oil stayed very clean for over 3K miles. When/if you drop the pan look for bits of plastic, likely from the cam chain tensioner shoes.
#14
Thanks, I got lucky on the sludge, the PO had hit a speed bump (so story gos) and damaged the pan and Records show dealer replacement in July, and last oil change. Happy to say that the Timing belt service & the egr leaks V cover & tensioner gaskets were done a few Kmiles prior to me buying the car at 89Kmiles.
and yes the oil does stay clean for many miles. With full synthetic I chose 5K miles for mi change intervil, will read up on what others are doing.
Again thanks for help and feed back
abpuma
09-17-2015 11:39 AM
CPLYONS
09-07-2015 07:19 PM
