Oil temperature gauge not working
Hi cars been laid up 3 yrs just woke her up flew through mot and has developed a new fault oil temperature gauge not moving is there a separate sensor or does the oil level sensor do both ?
Would changing the oil maybe sort the problem guessing I should make it a priority after 3 yrs off the road was started monthly during lay up cars a Audi A6 4.2 v8 1999
Looked at Bentley manual. Only showed 2.7 as separate temp sensor in oil pan. That said, many VAG cars have round dual purpose sensors. I would get under car and see what's connected to oil pan. Then unplug and clean any connectors. With any luck, cleaning might solve issue. If not, probably dealer part.
Try this:
Drain Oil, if you can, remove the sensor and clean it with carb cleaner, spray and clean all electrical connections. Put it back, fill oil and see if it goes away. If not, you'd have to do check/troubleshoot the sensor as per manual.
Gauge won't/shouldn't go bad so easily (yes, there maybe exceptions but not the norm). Most likely sensor/electrical/wiring~any fuses etc.
VA_Esfour
03-08-2009 09:41 PM
