Oil Temperature Gauge and Overheated Engine
2001 Audi a6 2.7t
1. My oil temperature gauge in my cluster on my dash in my Audi has not budged in about 6 months. How could I fix that and what could be the problem? I checked Vag-Com and there are no codes showing up. No check engine light or anything on the dash.
2. While I was driving I turned my air conditioner on. I have never seen this before with this car but the engine temperature gauge on the cluster started to move right to the point where it was 2 notches right of center? What could be causing this and how would I fix it? It does not do this in Econ mode (that is somewhat understandable).
When you have the A/C on and the car is moving, it is generally air cooled and that is all that is required. There is an auxiliary fan in the front though, and it comes on when the weather is hot and air cooling is not enough, or usually when you are sitting in traffic or just idling. So, if you turn the car on, and the A/C works and car doesn't over heat, but you let it idle for a bit and then suddenly the temperature starts to rise after a while of idling, the fan probably is not kicking on. When it overheats, just pop the hood if you can and look at the fan in the front by the radiator. If it is overheating, that fan should be going and I bet its not.
You can supply that fan with 12V directly and it should spin. If it spins, then you need a new controller for the fan, if it doesn't spin you need a new fan and may need a new controller also.
I second this advice. Your oil temperature sensor/level sensor is gone most likely and needs to be replaced, it is on the bottom of the oil pan and a few threads down will give more info.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
audijim113
09-03-2015 01:22 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
