Noise
Old 03-03-2014, 06:25 AM
Chief#16's Avatar
Default Noise
2004 A6 S-Line 2.7
83K miles
When I go over a speed bump (slowly) or go over a dip in a road, it makes a sound like my car is bottoming out (it's not obviously). Any idea what that could be?
Old 03-03-2014, 06:51 AM
georgeb944's Avatar
Shocks, control arms, tie rod ends, swaybar mounts, loose bolts, interior bits loose, fat mother in law in back seat...
Old 03-03-2014, 07:02 AM
SloopJohnB@mac.com's Avatar
Originally Posted by Chief#16
2004 A6 S-Line 2.7
83K miles
Dead hooker in the trunk.
Old 03-03-2014, 08:33 AM
Nialist's Avatar
I'm with you on this one. Seen it all too often.
Old 03-03-2014, 10:20 AM
thall6594's Avatar
2004 A6 S-Line 2.7
83K miles
Mine does that, it's almost like a crunching sound, right? I know I have bad lower control arms.
Old 03-14-2014, 12:52 PM
Chief#16's Avatar
Default Thanks~
Thanks for the help, guys. I did a very thorough visual inspection of the back seat and the trunk. I found nothing heavy in there that would cause the issue. I even did a double-check just to make sure I wasn't missing anything (human or otherwise). I was truly hoping it was going to be that simple.
I took it to my local shop and had them do a similar visual inspection. They found nothing either. However, they suggested doing an inspection on the front end where the noise was coming from. Ta da - they found it!
I ended up needing upper control arms, shaft outer boots, and sway bar c-links....whatever the heck all this is.
Old 03-15-2014, 06:17 AM
Just Me's Avatar
actually, live ones make a lot of noise too.
Old 03-15-2014, 07:25 AM
thall6594's Avatar
How much did the arms set you back?
Old 03-17-2014, 02:44 PM
Chief#16's Avatar
$267 for control arm bushings installed
Old 03-17-2014, 09:16 PM
thall6594's Avatar
So the arms are fine, you just needed bushings?
How many bushing did you have replaced?
Quick Reply: Noise
