Trunk lid issue when opening.
Need feedback regarding a trunk issue that has started. When opening the trunk lid the trunk latch locking mechanism locks all 4 doors on the car, when I use the key fob to remotely open the the drivers door the lock will open momentarily and lock immediately. FYI the drivers door lock latch has been replaced.
Thx, will do a wiring check from latch to hinge arm.
Noticed in ETKA that there is a micro switch by the lock latch, wonder if this could be the suspect? this could be the switch warning for trunk open/closed on instr. cluster.
Your hunch was right!! Did a wiring check and found all but 2 wires in the harness cut just above trunk hinge wire cover and found 1 wire cut in 2 places.
Tried to search for harness p/n on ETKA with no success, so just ended up splicing the harness wires back together, problem fixed.
Thanks for your help.
GeoX750Li
15
03-18-2022 07:26 PM
ceroberts75
07-11-2014 05:20 PM
dripppps
01-02-2013 04:52 PM
93_Audi_90CS
12-21-2009 09:16 AM
vtville
9
06-26-2006 10:57 PM
