Pad wear indicator lit in console...how soon to change?
#11
The sensor goes off when there is still plenty of material left from metal to metal. Even then, you should be replacing the rotors anyway so who cares, it will still stop.
#13
LOL…audi rotors hardly ever in spec after use.
But good news…just grind off the outside rotor ridge on the outer and inner sides of the rotor and slap in new pads. You can probably get away with 3-4mm of wear on both sides before the rotor gets too thin to function and even then it will probably function if the caliper pistons don't go too far out and ****/jam.
#14
Yes, rears about twice as fast as front.
OTOH, if you use your brakes heavily then the fronts will wear out first.
#15
Problem I have is letting rotors wear thinner or machining them, your removing heat absorbing material. The thinner the rotor gets the more its going to warp and distort under heat, and you may end up with awful shake using the brakes and end up doing the job again.
TNT13
RS4 (B7 Platform) Discussion
01-27-2009 11:58 AM
ScottJ
10
03-08-2005 04:12 PM
the senator
18
11-19-2003 04:26 PM
