Question regarding MAF wiring
Hi!
My question is regarding the connection between the maf & harness. The wiring to the female connector has been pulled out , would appreciate any help with reattaching the wires correctly.
A6 c5 3.0 2002
The wire colors are:
yellow (a little thicker than the rest)
green
green/yellow stripe
black/white stripe
purple/yellow
thanks in advance!
A6 c5 3.0 2002
green
green/yellow stripe
black/white stripe
purple/yellow
thanks in advance!
Green terminal 3, Black #1, Green/yellow #2, Violet/yellow #5, Green #4.
That is the order from left to right in the manual schematic. Also, the Green to terminal 3 appears on the top of the plug, while #'s 1, 2, 5, and 4 are on the bottom side.
Not being an expert in reading these schematics, I'm not sure if there are any numbers on the part to identify the locations. Nor if that odd number sequence is correct.
The part/connector has #s on it.
much appreciate the response.
Your best bet is to buy a new connector...it comes with pigtails from the connector and you splice your wires onto the pigtails. It's possible to remove the terminals from the connector and perhaps reattach or solder the wires to the old terminals but in my experience the terminals are damaged and really difficult to reinstall.
Im@wesome~ out!
11-13-2007 08:56 AM
dagmz6s
9
01-06-2007 07:26 PM
BLKB6A402
03-27-2004 09:46 AM
180q
12-10-2000 08:24 AM
