Replaced window regulator, window still jamming
Just bought an '03 A6 Quattro a few days back. Right rear passenger window jammed while rolling it up. I pulled out the window assembly and replaced the regulator as the !~@# plastic runner had cracked. After I installed the new regulator the window is still jamming. I noticed that the window still has quite a bit of play in it while rolling it up below ~ the half way point. The motor seems strong. No odd noises and when someone pulls the back of the window towards the front as it's being rolled up, it does go all the way up. Is it possible that the window is out of alignment or needs some other adjustment?
I think there are some sliders missing.
If you can't find a pic on the web you can always take apart the left rear and observe how they're installed.
If the silicone spray doesn't work, you may need to inspect the felts it runs up and down carefully, that they are not kinked or damaged. You may need to replace the felts. Also I find the cheap aftermarket window regulators absolutely suck, and do this stuff, or just break in a few weeks.
Hendie
03-01-2019 09:55 AM
man_utd_4eva_727@hotmail.co.uk
10-22-2016 06:22 PM
skidmark
Audi allroad
17
06-20-2005 05:48 AM
