2000 A6 4.2Q changed battery and seeing fault codes
Old 01-26-2014, 04:29 PM
ather's Avatar
Default 2000 A6 4.2Q changed battery and seeing fault codes
Hi All,
I just changed the battery on my 2k A6 4.2Q and noticed a few things stopped working. The sunroof does not open anymore, the radio says "SAFE" (guess it needs a code). I ran the vag-com and also noticed a bunch of other items showing up now. Fyi, I changed the both S1 02 sensors recently and am seeing the fault codes re-appear. Not sure why. Any thoughts on what I should do to fix them? Do I need to reset the computer? If so, how? Apologies for the long thread.
Address 01: Engine Labels: None
Part No: 4D0 907 558 S
Component: 4.2L V8/5V 01 0008
Coding: 06652
Shop #: WSC 42286
VCID: 3D71ED2D37EE1EF6BF5-5142
5 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16692 - Cylinder 8
P0308 - 35-10 - Misfire Detected - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1
P1131 - 35-10 - Internal Resistance too High - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-10 - Internal Resistance too High - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 BS
Component: AG5 01L 4.2l5V USA 1414
Coding: 00002
Shop #: WSC 02325
VCID: 79F9393D6346E2D6D3D-5142
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C3700A98C3477FE68B-5124
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 K
Component: A6-Klimavollautomat D64
Coding: 00180
Shop #: WSC 02325
VCID: 224B3E51AE50410EA27-258E
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 F
Component: Airbag Front+Kopf 0002
Coding: 00404
Shop #: WSC 02324
VCID: 3365CB1501AAD886591-5142
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
------------------------------------------------------------------Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487
Component: E Lenkrad Elektronik D03
VCID: E9D9E97D93E6D256A3D-4B9C
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 980 M
Component: C5-KOMBIINSTR. VDO D09
Coding: 03283
Shop #: WSC 00000
VCID: 2F6DC765ED82FC663D9-5142
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
VCID: 306FC419F0BCE39E243-4ED0
3 Faults Found:
00668 - Supply Voltage Terminal 30
07-00 - Signal too Low
01559 - Drivers Door
58-00 - Can't Lock
01561 - Rear Left Door
59-00 - Can't Unlock
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 A
Component: Sitzmemory D05
VCID: 2B55D375D99A8046111-4AEC
3 Faults Found:
01447 - Sensor for Driver Seat; Height Adjust (G231)
29-10 - Short to Ground - Intermittent
01448 - Sensor for Driver Seat; Tilt Adjust (G232)
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
VCID: 26432241C278BD2ECEF-522E
Address 55: Xenon Range Labels: 4B0-907-357-DYN.lbl
Part No: 4B0 907 357 B
Component: dynamische LWR D03
Coding: 00020
Shop #: WSC 02325
VCID: 275D2F45C572A426F59-4B1E
1 Fault Found:
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 195 A
Component: Radio D00
Coding: 00017
Shop #: WSC 42010
VCID: 1E330AA19A2865EE86F-4B1E
1 Fault Found:
00855 - Connection to CD changer
49-00 - No Communications
End ------------------------------------------------------------
Old 01-26-2014, 04:49 PM
ather's Avatar
One thing I would like to add is that when I start it up, it idles rough for a minute and then seems to idle more smoothly for some reason like it corrects itself. It happens every time I start it no matter how many times I do. Not sure why that happens.
Old 01-26-2014, 05:51 PM
jcman's Avatar
Clear all "along with the old dated" codes, enter your radio code, drive the car as usual.
After a few days check vagcom for codes aside from your possible door switch acting up like just about everyone else "super cold temps" you should be OK.
Report back.
Old 01-26-2014, 05:55 PM
jcman's Avatar
Just to clarify; Old dated codes are codes from the past but maybe you check your codes often or at the time of a repair.
oakland8124
11-03-2018 05:48 PM
that_tg
01-11-2013 07:25 AM
Disher04
03-07-2009 03:48 PM
Yu_Power
VAG-COM Discussion
09-26-2004 09:52 AM
Yu_Power
09-23-2004 09:23 AM
Quick Reply: 2000 A6 4.2Q changed battery and seeing fault codes
