Right Rear door problems
Old 12-10-2014, 10:06 AM
Glacksy's Avatar
Default Right Rear door problems
Hello, i have a problem with my right rear door.
When i open it, lights in the car does not go on. And the lights below and in the door doesn't light up. It's like it doesn't get power.
However, here's the weird thing... the window regulator have power and works fine. its just the rest.
I opened up and removed the panel of the door, dried it all up and checked wires. nothing.
i checked fuse box but there wouldn't be one fuse for just the door, would it?
wouldn't it affect the whole interior light or something like that?
Have anyone experienced this issue before?
Old 12-10-2014, 12:30 PM
SloopJohnB@mac.com's Avatar
Check your fuse panel again.
Old 12-10-2014, 03:16 PM
twentysevenlitres's Avatar
It'll be the door open/close switch.
Some Audi's use regular pressure switches on the door frame somewhere, but may also use a micro switch on the door latch.
(I don't know the C5 platform, so if you can't find an obvious switch open a door which works the interior lights and run a screwdriver through the latch and see if the lights extinguish)
Old 12-11-2014, 05:49 AM
Glacksy's Avatar
ill try both as fast as possible. thanks for answers
Old 12-12-2014, 12:49 AM
kelisko's Avatar
It might be that there is a loose connection in the axilla of the door. Remove the plastic accordion and make sure nothing is disconnected there.
mawho
12-04-2010 08:20 AM
Kid Red
08-31-2008 12:11 PM
h2o4rdallroad
Audi allroad
10-15-2007 11:02 AM
clancy
04-19-2004 05:10 PM
Quick Reply: Right Rear door problems
