s6 lower control arm bolt?
#11
Same Problem
Hey guys,
Im trying to wrap up this marathon job on my car and I am on to the lower front control arms and the only how tos I have seen are for A6's and apparently they are a little different than S6's ....
I have the rear lower bolt loose and about half way out but then it hits the underside of the car with i'm guessing about 2 to 3" of bolt still inside the bushing and mount.
from what Im seeing it looks like the only way to gain any room would be to drop the sub frame! I really hope that isn't the case!
Does anyone have any tips or tricks?
Has anyone figured out the easiest way to do this? I’m not too comfortable dropping the sub frame if I don’t have too but I’m not seeing many other options.
#14
Reading the message above mine I think I did cut the bolt with a dremel and put the bolt in from the other side.
#15
I’d be happy to send pictures if you think that may jog your memory haha. From what I can tell I don’t have many options but dropping the frame. Which I really don’t want to do…
#16
When I looked earlier I saw a comment above mine that said to cut the bolt off and the run the new bolt in from the other side, after reading that I'm positive that is what I did. Work the holt out as far as you can, use a dremel with a cut off disk and cut the bolt off, then push the bolt out the rest of the water from what was the nut side. When assembling put the bolt in from the nut side, if I remember it is still a bit challenging, especially lining up the nut, but much easier than dropping the sub frame!
ESFO
12
11-03-2006 09:20 AM
SilverB6A4
07-07-2006 09:35 AM
Hey Reg apparently the owner of that car is from Ft. bu tI don't ever remember seeing it around town
jrossaudi
Rocky Mountain Discussion
08-31-2005 05:42 AM
Apparently there is a big meet (cars in general) at Marcus Dairy in danbury ct tommorow...ne1 going?
SlickBlackS4
NY / NJ / CT Discussion
09-24-2004 04:59 PM
