secondary air injection - AudiWorld Forums
Old 04-09-2014, 03:22 AM   #1
Default secondary air injection
Hi all, have 2002 a6 3.0 v6 a/t quattro which has random misfire codes for 2 months. Changed 6x plugs, 3 coil packs and replaced both flex on downpipes. Now have sai low flow to bank 1 idle is fine, misfires always around 2krpm causing cel to flash. Can anyone aged any light on this, I'm not too scared of getting my hands dirty.
clueless racer is offline   Reply With Quote
Old 04-09-2014, 04:11 AM   #2
Do you have any other codes? What are you using to scan? A generic OBD scanner? Or a Vag-Com?
jseklund is offline   Reply With Quote
Old 04-09-2014, 07:36 AM   #3
SloopJohnB@mac.com's Avatar
It wouldn't be unusual to have a failed SAI pump..they can be rebuilt (by you..check youtube or the resource menu button) or replaced. Vag-com would show you if the thing is working or perhaps you can listen for it to start up (I don't know..a long screwdriver touching it with one end to your ear while someone else starts the car from cold?).
SloopJohnB@mac.com is offline   Reply With Quote
Old 04-09-2014, 02:02 PM   #4
Quote:
Are you suggesting that a bad SAI pump can cause a misfire or rough idle?
thall6594 is offline   Reply With Quote
Old 04-10-2014, 05:36 PM   #5
Using obd, kinda hoping the vac lines are partially blocked as the car was sat around for a few months before I bought it.
Old 04-11-2014, 05:20 AM   #6
Quote:
hope springs eternal…if the lines weren't blocked before, a few months sitting around wouldn't likely block them unless spiders got into them, very unlikely.
Old 04-11-2014, 01:12 PM   #7
Changed the panel filter when I got the car, and there was leaves and crap in the airbox and maf due to a clip not being fastened. Wonder if it's found its way into sai? Will find out tomorrow :$
Old 04-12-2014, 09:45 AM   #8
Well it turned out it was the PCV, stripped it down, cleaned and reinstalled. Took car out for a test and it no longer sounds like a Scooby, cel has gone out. Fingers crossed it'll last till the replacement arrives O I guess the previous owner overfilled with oil at some point.
Old 04-12-2014, 12:06 PM   #9
PCV…vas is dis? The 3" round thing that honks like a goose when it shouldn't?
I've not had much luck with those…I've replaced them to stop the honking.
Thread Thread Starter Forum Replies Last Post
Letter from Scott Keogh-President of Audi lmariorod Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 5 09-07-2016 07:00 AM
Fault Codes Kerry G Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 06-07-2016 03:55 AM
Help with 2005 Audi A6-3.2L quattro BKH bballfreak A6 / S6 (C6 Platform) Discussion 4 10-12-2015 06:14 PM
activated charcoal cabin air filter for a6? random512 A6 (C7 Platform) Discussion 9 10-05-2015 08:00 AM
A6 1999y, 1.9tdi avant FWD air springs replacement. Markuzas A6 / S6 (C5 Platform) Discussion 5 09-28-2015 07:38 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
