skc pin retrieval help... got software.but won't connect to cord
#11
Does anyone know if the immobleizer will lock up if I have the original key within range of it and I use the unprogramed key it starts and goes in gear I haven't actually driven it like this yet... but immobleizer light keeps flashing I'm just worried it is in a pending state and will just lock up at some point and the original key will not unlock the immobleizer. And only dealer can. Anyone know about this???
#12
Before trying to do any installs, try putting the key that works by the e-brake and go for a short trip - not just start it up. If you do decide to do construct a keyless start like this, technically you don't need to hide an entire key - just an RFID tag for the immobilizer. And you really should fasten it somewhere much closer to the ignition barrel - there are plenty of detatchable panels in the surrounding area.
If you were able to pull a 4-pin SKC from it, you should be able to use that for programming immobilizer tags/keys (and FOBs) with VCDS. (Vag Commander is a totally different program and tool). Remember that when inputting the 4-pin SKC for login, it takes a zero before the 4-digit PIN (5 numbers must be input). So if your 4-pin SKC is 1234, you'll input 01234. If you're reading SKC with e.g. Vag Commander, and you get a 3-digit readout - this means your 4-pin SKC starts with a zero (like 0123). In this case you'll input 00123 at the VCDS login.
For reference:
7-digit SKC (Immobilizer 3 -> ) is not something you can extract from the ECM. What the 7-digit SKC really is, is part of a sort of checksum/hash of your 4-digit pin - composed of the 7-digit SKC, VIN/IMMO-IDENT, date, workshop and importer code. The software and ECM/Cluster takes all this, calculates your 4-digit pin from it and hands it off to the ECM/Cluster. So basicly, the 7-digit SKC is just one part of a complex combination, to hide the real 4-digit pin code. The real reason for this is so that VAG workshops can't look up your "permanent" 4-digit PIN in a database, nor does factory/VAG tools show the 4-digit pin it calculates, on display. Combined with the fact that the code is only valid for a set day (date), this makes it much less likely to be abused by an unfaithful employee, database hackers etc.
Now, with Vag-Tacho/Vag commander and the likes, you can extract the 4-digit pin by reading it off the cluster/ecm. Official VAG tools don't do that.
Audi/VAG stopped giving out these 7-pin SKC codes in 2005. AFAIK, with dealership terminals this is done "online", and that 7-pin SKC is "blacklisted" on Audis servers after 24 hours. If you DID happen to have a friend at a dealership willing and somehow able to give you a code and all these details - it worth noting that with VCDS, you'll be able to login with those numbers whenever you want. I'm a bit unclear as of wether VCDS will actually show you the 4 (5) digit pin that is calculated from the 7-pin SKC and the other stuff, or if it will just appear as astrixes etc, on the screen.
For reference:
#13
For reference:
For reference:
#14
For reference:
For reference:
But I do have a question the only programed key is a flip key and it has a battery is that needed for the chip to be read? I figured it was for the alarm bottons but the spare has one too it also has a flash light but I almost felt they added that since it already had a battery please help called best buy made appointment and installer just said I have to remove the chip he won't be responsible for removal and possible breakage.... need to know by Sunday the 7th thanks buddy I appreciate it
#15
Battery isn't needed, that's only on immo3+ cars where it's an active RFID system (mainly used for the KESSY push start stuff).
These older immobilizer systems are really simple, you only need the 5 digit PIN to do any key programming, none of that 7 digit only-for-one-day crap that the newer cars need.
Read this:
http://wiki.ross-tech.com/wiki/index...ching_(Cluster)
If you follow that, you shouldn't have any issues.
Read this:
#17
I found that if I take the transponder out of the only key that is programmed . And hide that in the dash(what the tech needed was a key that was programmed he can hide in dash by immobleizer to trick car into thinking keys in ignition while it's remote started.) As opposed to a whole key. Then if I take all chips out of all other keys to be used then ta da. The remote start works and I can start it with any cut key with no chip. .. no more hassle and I get what I needed... just a spare that can start it and remote start that's operational.... what do u guys think I just feel if I already found solution that's risk free why take the leap and pray for best and if it goes bad it's BAD.. $1500 BAD just to be able to drive it.... BIG JUMP FOR ME. but tell me what u think
#18
Update
OK so tried to get alarm installed. It was a bust. I had called ahead to see if I still needed to cover anything else for the alarm and geek squad at best buy told me no. Upon taking the car for install was informed I needed another $300. In parts and labor. But what gets me is, not only did I call ahead. but I bought the alarm in a package deal on black Friday for $500. With installation. So if I still have to pay for labor then want did the package deal include?? Just word "installation".... I mean really.... but to get on topic. I guess it wouldn't have worked anyway. Before when I used my spare key(no chip in side)with the original flip key on the key ring next to it. I could start the car and drive it. The immobleizer light would flash but car would start and drive.. but when leaving best buy and seems everytime since if I try and use the spare the immobleizer kicks in and car won't stay running... but if I pull the key out turn the car on with the original flip key then turn it off restart it with the spare key then it works... I didn't have to do that before... werid.. so now I'm back to square one so I guess I'm going to get a new set of spares and try and program them with the vcds. If that don't work I have another instrument cluster/ immobleizer I can try and swap in and try to program again. Of both fail then I give up.... time to cough up the $1500. For new cluster/immobleizer w/install and programing 2 keys Damn it... I hope I can get the vcds to work..... please.... oh please work...... thanks again for all help and advice
#19
This reminds me of the old joke, "How do you double the value of a Yugo? ... You fill the tank with fuel." So, "How do you double the value of an old Audi??"... "You buy some new keys for it."
#20
wdambro
06-22-2009 01:41 AM
three_man_riot
03-15-2006 08:58 AM
