Solid to flip key
#31
What elchinoloco said - dealership (Møller) is probably the only one that can precisely tell you what FOBs you need. But unless you know someone there, they don't give out part numbers as a policy.
Some say 315MHz models are for Japan and US, 433.92MHz for Europe. I only read this from a forum source, I cannot vouch for it. The part number for your [35] Central Locks module is likely to give you a pointer. Mine ('99, late '98 production Norwegian A6) is 4B0 962 258 E, it takes 433.92 MHz remotes. A VCDS scan will give you the part number for the module. Your FOBs are also going to need new ID48 tags (for the immobilizer) - so check that they have it if you buy parts online.
VagTacho, Vag (K+CAN) Commander or similar for the SKC recovery (I've only used Vag (K+CAN) commander myself), VCDS for programming immobilizer tags and matching (new) FOBs.
#34
Just ordered one from ebay, just for testing. When i was trying to adapt the fob, i used VCDS, but in adatpation modus, channel 01 and 21 was not available so i followed this guide in this link: Ross-Tech: VAG-COM: Remote Control Matching Info
But with that i need to have a cut key, mine is uncut for the moment. Is there any other ways to program a fob without a cut blade ?
#37
Here's how it looks from the US
#38
If you're referring to the point where you use a secondary FOB to put in the door / push lock/unlock - according to ELSA you can "trick" this by pulling the driver side door card and jumping the wires at the door lock (emulating the secondary FOB and key operation). I'm not sure what signal goes to what wire/terminal though - still haven't quite got the hang of the wiring diagrams.
