Go Back   AudiWorld Forums > Audi Models > Audi A6 / S6 / RS 6 > A6 / S6 (C5 Platform) Discussion
Register Forgot Password?
Welcome to AudiWorld Forums!
Welcome to AudiWorld.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the AudiWorld Forums community today!
LinkBack Thread Tools Search this Thread Display Modes
Old 10-04-2013, 07:00 PM   #1
Account #: 264209
Default speedometer stopped working....WTF
2004 Audi A6 2.7t quattro automatic..161,000 miles...the speedometer stopped and i ran codes and it said VSS , replaced and it still doesnt work...its so weird cause it will jump around one minute and then stay stuck on 0, then it may work for 30 minutes then stop again.....what the hell can it be?
jimmyjames72 is offline   Reply With Quote
Old 10-04-2013, 07:48 PM   #2
Account #: 171699
tester123's Avatar
Quote:
possible intermittent wiring / loose contact issues..?
ʘ˥ Pearl White А6 Ч.2ℓ Quattro
Sport, cold, everything -Nav.
No more OIL or COOLANT leaks! │ T-Belt, Water pump & Valve Covers DONE! │ Trans & Diff Fluid DONE! │ Bearing & Inner Tie-rod Next │ Steering leaks?
Fuel Banks 1 & 2 Lean issue fixed (finally!)
Rebuild Bosch 150 Amp Alternator (save major $$$)
tester123 is offline   Reply With Quote
Old 10-04-2013, 08:00 PM   #3
Account #: 264209
loose contact wires where?
Old 10-05-2013, 12:49 AM   #4
Account #: 260385
Is every other gauge and light in the cluster functioning properly? I had a B5 A4 that had a flickering speedo needle. It got worse and worse and eventually stopped altogether. When the headlights were turned on the dash went completely dead and the all illuminated buttons on the interior went off e.g window buttons etc. I had to replace the dash to fix that problem
nzaudia6 is offline   Reply With Quote
Old 10-05-2013, 06:00 AM   #5
Account #: 264209
everything works fine except the speedo and then in turnmesses up the gas gauge and the odometer also.....what can this be...before i have to go to audi dealer.....
Old 10-05-2013, 07:36 AM   #6
Account #: 171699
tester123's Avatar
from vss and possibly behind the instrument cluster... Scanned to see any codes?
Old 10-05-2013, 08:15 AM   #7
Account #: 264209
yeah the code it ran was calling for the VSS to be changed...i changed that and it still didnt work....some said the cluster has to be changed...but there is something like an imobilizer associated with that.
Old 10-05-2013, 09:39 AM   #8
Account #: 220156
The instrument cluster gets the VSS signal, then sends it to the ECU which will set a code. It is not getting VSS, because the instrument cluster has failed. Its not uncommon to have the electronic speedometers fail.
1991 Audi 200 Turbo
1999 Audi A6 Avant 2.8
1998 Audi A4 quattro 1.8T
Prospeeder is offline   Reply With Quote
Old 10-05-2013, 01:13 PM   #9
Account #: 264209
so if i have to replace the speedometer cluster, is something you can do yourself? it lookds fairly simple...a few screws in the front and it comes right out..or is this an expensive job for an audi dealer to do?
Old 10-05-2013, 03:17 PM   #10
Account #: 171699
tester123's Avatar
Just found out in the manual:
The Immobilizer is a theft-deterrent device that adds a layer of security that is standard on every Volkswagen and Audi model. This is achieved with an electronic device embedded in the ignition key, an Immobilizer Control Module and an electronic link to the Engine Control Module.
Working with Immobilizer Systems
Audi limits access to certain functions by requiring a Personal Identification Number (PIN).
PINs are required for the following functions:
Adding new keys
Replacing lost keys
Replacing Instrument clusters
Replacing Engine Control Modules
Other repairs to the Immobilizer system
GeKo
Audi uses an on-line Immobilizer Adaptation (PIN) delivery system, known as GeKo. GeKo is a vehicle anti-theft protection system. With this system, the VAS 5051 or VAS 5052 diagnostic tester is connected to the vehicle and via Internet to an online database called Fazit. The identification of the tester and vehicle are passed to the database and the correct PIN is passed to the vehicle in a secure link without direct user interface.
AudiWorld
Audi R8
Paid Advertisement
Tags
1999, 2004, a6, audi, quattro, quit, speedometer, working
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2014 AudiWorld.com Audi Enthusiast Community
