T17r connector?
T17r connector?
I have problem in T17r connector, 17 PIN white behind Instrument panel centre. My Navigation Plus system is out of power. Both fix and SAFE line. Both lines comes from this connector. BUT I do not know where it is.
So can somebody help and say where this T17r connector is in Instrument panel centre. Up or down in centre area. Behind A/C panel or ???.
Thanks!
Thanks!
You might need to state the year and model and engine
Thanks!
Thanks!
Google is your friend.
T17r, white, behind instrument panel, center
"T17r - Connector 17-pin, white, behind instrument
panel, center" is what/where Bentley says it is.
One of the wires going into it is orange/lilac or orange/violet wire which also leaves it.
Hello. T17r was fine. It was behind A/C panel left down there. A/C panel off and You can see it.
CCM was fine. Y/R cable was onko 6V so the problem is in V37 or A50 positive connector.
So every cablestack open and trying to find these 1,cable in 4 cables out pagages. Best quost is that these are under left front or back door or under left front chair.
So next phase is to locate 1R/Y cable in and 4 R/Y out and olen the rubber cover and check problems.
The carpet is dry but under it was some moisture.
