audi a6 c5 2.8 1998 trany problems please helppp
ok i just change tranny on my audi a6,and a try to drive car.. but is going into a limp mode, car stuct i 3 gear..but when a stop car and turn off engine a start again it going till 3 gear and stuct again..check engine light is on a give me code p0717 (input/turbine speed sensor circuit no signal) where can i find thet sesor,and what can be wrong??why car stuc in 3 gear? PLEASE HELPPPP anyone i dont know what to do anymore/// Thanks
Take it to a transmission shop that knows what they're doing. There are just so many things that could have gone wrong with the old transmission removal and new transmission install, not to mention whether the 'new' transmission is the right one or is any good anyway.
I hate to say it but if you used the wrong transmission code it will do this. Also if the system detects enough slippage it throws it in limp mode. You may have just replaced it with a junk transmission. You could try the speed sensor, its inside the transmission attached to the valve body.
Hey, my friend! I have a question for you. I have a 99 a6 quattro and it seems that my forward gears are very sluggish . Reverse works with no problem. It drives but takes forever to build up speed. Do you think this could be a clogged tranny screen or screwed up tranny? I checked the fluid and it was blackish brown color. Any info would be greatly appreciated
ok i didnt check code on tranny but i but I remembered thet on a old tranny input speed sensor is ben located on valve body but on a new tranny is been located on a tranny not on a valve body but i put down thet sesnor and valve body and put my old sesnor and valve body can this been thet why is car in a limp mode or? what are my options to do now anybody ideas? do i have some options or pot down new tranny and find same tranny like oldone..or what are my option to make sure what is wrong i am mechanic but i am not very good whit automatic tranny..becose i from europe there are just manual tranny hehe )
