Window regulator?
Old 09-02-2013, 04:27 PM
thall6594's Avatar
Default Window regulator?
My front passenger window does not go up on its own anymore, it will go down no problem but when going up it goes slowly and gets stuck. Is this the regulator that I need to replace or is it a different part?
Old 09-02-2013, 07:19 PM
lucio_liu's Avatar
most likely a plastic clip broken... take off door panel screws then you can check it out.
Old 09-03-2013, 03:48 PM
Zaphodb17's Avatar
you probably need this:
http://www.europaparts.com/window-re...b0837463b.html
Old 09-04-2013, 02:02 AM
OGBULLYLOCDAWG's Avatar
Originally Posted by Zaphodb17
I wonder why the price for these regulator clips have jumped so high? These were like $12 when I purchased mines from the dealer a few years back.
Old 09-04-2013, 09:43 AM
thall6594's Avatar
Was it the part you needed?
Old 09-04-2013, 10:37 AM
Airbag's Avatar
wow they are brown now ? i thought the latest, latest, latest ones were pink ? ..
they must be making them out of unobtanium now..
Old 09-04-2013, 01:03 PM
Yeah, in my case that was my problem. The video Airbag posted shows you how to replace it. You can check it beforehand if you aren't sure, but the problem is usually one of the clips. There's 2 on each front window.
Looks like there's cheaper alternatives on ebay, not sure if they're OEM quality though.
Old 09-08-2013, 12:03 PM
thall6594's Avatar
Before I order the clips, do I need to order two or does it come with two already?
Old 09-09-2013, 07:44 AM
Airbag's Avatar
you buy them each as far as i know but ask the seller ... if i were you i would get them from Audi .. then you are guarenteed to get the latest rev, not soemone clearing out old stock.
Call Audi and ask them what colour the latest rev is at least , then you will know what you are getting.
bballfreak
9
04-14-2019 06:59 PM
fluidparkour75
08-18-2018 02:57 PM
Turguin
Audi A3 / S3 / RS 3 MKII
11
04-14-2017 07:39 AM
iamdrewseph
10-01-2015 11:33 AM
NYCtt123
09-27-2015 05:04 AM
Quick Reply: Window regulator?
