Timing belt change problem
I am trying to replace my timing belt and water pump but have run into a MAJOR problem trying to remove the fan pulley assembly. One of the 6mm hex bolts appears to be stripped and I need it to come out in order to remove the assembly. Any suggestions on what is best way to remove this bolt? Thanks in advance for any help.
there are extractor tools or you can sharpen a 7mm
Then use a hammer-driven impact wrench to remove the bolt.
Replace the bolt with a new one! You might consider replacing all of them. If you look closely they might have a greenish tinge which is Audi's non-galvanic corrosion coating. If not, then use green loctite when you put it together. Green is IIRC the weakest anaerobic adhesive/sealer. Unless audi specifies a sealer for the bolts.
Thanks for the help, Is there anyplace I can find the exact bolts that are used for this bracket? I want to replace all 4 of them if I can but I cannot find the type/size listed anywhere. I live over 100 miles from the closest Audi/VW dealer so any help would be appreciated.
As always, you can find part number for it and order it online.
if you have a problem solving this the way described above, i would do it like this;
drill off the entire head of the bolt.remove the other bolts.now that the complete assembly is removed, you also have no more tension on the bolt.the remaining thread should be quit easy to remove therefore.you can use some good grippers to take on to the threaded piece sticking out and remove it like that.
suc6!
suc6!
100miles…ouch. OTOH, you're probably a ways from ANY dealer at that point.
I HIGHLY recommend trying the hand impact tool. You should have one in your toolbox anyway.
I would simply order them from ECStuning.com; the screws are $0.99 apiece. Or call the audi dealer with the p/n N90827702, chances are they have them in stock and will mail them to you for a fee or order them online.
Audi C5 S6 Quattro 4.2 Engine Cooling Water Pump - N90827702 - torx screw - Priced Each - ES#470900
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
