Timing Belt replacement, camshaft sprocket wings are off.
#11
#12
I did mark the cam sprockets with sharpie and mark the camshaft back plastic cover, so I should be able to just rotate them to realign back to where they were, then take off the sprocket so that the wings line up and then reinstall the sprockets and the belt, rotate it over and it should be good.. correct?
#13
Then redo the timing job with the camshaft lock bar.
#14
Nope. You've already turned the crankshaft against something so who knows where you are, timing-wise.
#15
If my timing is off, is it okay to start the car? Or will it all just blow up..
#16
I think I'm okay. Today I got the drivers side camshaft into place, and got the crank to TDC. Then I got the passenger crank to line up and got the locking bar into place, rotated everything with the timing belt on about 15 rotations for good measure. I got everything back on except the bipipes and diverter valves. Tomorrow ill put them on and start the car...
However, since you've rotated the crank that many times without problems it's likely you're ok.
You might want to run a compression test before you start it. No compression on one or more cylinders is an indication of bent valves. Then you'd have to borescope it or pull the heads to find the bent one(s) (I'd scope the cylinder with no compression).
#17
After I put everything back together, I started it up, sounded great! In fact my misfire from before went away..? Must have just been an uncleared code as I cleared the codes before I started it.
But I still have an extreme coolant leak, looks like its coming from the thermostat, leaks out when I add water to the reservoir, not even when its started.... I'm gonna take it apart today and look into it.
#18
Cracked thermostat housing
I figured it out, the plastic thermostat housing is cracked! I didn't see it when I took it apart before..
New question: I plan to just buy an upgraded aluminum housing from the pre 2001. Any recommendations on where to get one? I was thinking here: Thermostat Housing, Aluminum (OEM) for 2.7T, 2.8L - JH Motorsports Inc. - -- JHM. Shifting you to
Question is, this is for the S4/RS4. Will this fit on my A6? Looks the same.. but looks are deceiving
**EDIT**
Found one at EuropaParts! Thanks guys.
**EDIT**
#19
**EDIT**
**EDIT**
#20
N'Syncro
33
02-16-2020 03:12 PM
irelandbuyer
07-21-2019 01:54 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
