TONS & TONS!! of smoke
Old 10-16-2014, 06:51 PM
  #21
raj99's Avatar
Originally Posted by Just Me
good info. So what are these magic seals made out of, that they can withstand > 1000 deg?
Grant
Adamantium. Lol 😁
Old 10-17-2014, 09:26 AM
  #22
CRuby's Avatar
Grant
If you're referring to turbo rebuild, there are no "magic" seals included. Just a new brass journal bearing, among other replacement parts. It's call a rebuild kit. Although you might consider it magic if it fixes your leaking turbo problem.
Amazon.com: Turbocharger Rebuild Rebuilt Repair Kit for KKK K03 K04 K06 Turbocharger Borg Warner: Automotive Amazon.com: Turbocharger Rebuild Rebuilt Repair Kit for KKK K03 K04 K06 Turbocharger Borg Warner: Automotive
Old 10-17-2014, 10:04 AM
  #23
ake11's Avatar
how about sending them out to be rebuild would that be worth it?
Old 10-17-2014, 12:29 PM
  #24
georgeb944's Avatar
Probably more expensive than the $800 that you paid for the car. Plus, you get to pull the motor to remove/replace the turbos. If your time is worth $100 per hour, that also is worth more than what you paid for the car.
When you're done, you will have more in the car than it would sell for.
Do the math....
Old 10-17-2014, 08:10 PM
  #25
seishuku's Avatar
Do the math....
Turbo rebuild usually aren't that expensive, maybe $200 per turbo, which also includes high speed balancing.
Also,there are seals, a journal bearing doesn't keep oil in, the turbine shaft rides on a film of oil passing between the bearing and shaft.
There are carbon or graphite spring seals at both ends behind the turbine and compressor wheels.
Old 10-23-2014, 08:03 AM
  #26
Osmosis's Avatar
I am curious to a few things. Did this problem gradually start or did the car just start smoking bad all of the sudden? Has the smoking become worse over time?
also, what color is the smoke??? Black - fuel/oil. Whiteish = coolant
And finally, what do your plugs look like???? Black covered with oil??? or wet smelling sweet???
Inspecting the plugs will tell you a lot about what is going on inside the engine
There are plenty of youtube videos on how to rebuild turbos and the kit on amazon looks similar to the rebuild kit I did to my GMC Syclone...which was easy.
Old 10-24-2014, 04:41 AM
  #27
Just Me's Avatar
OK, so there are no seals, as i thought. Its just an oil tight ( mostly) bearing.
That was my question - someone referred to "new seals". I could nto imagine any seal material handling the heat.
G
Old 10-24-2014, 06:15 AM
  #28
seishuku's Avatar
Not the exact turbo, but all turbos have to have an oil seal of some kind, otherwise you would have oil spraying out the exhaust.
T1no33
Audi A3 / S3 / RS 3 MKII
15
02-09-2019 01:55 PM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
ober
17
09-30-2015 09:27 PM
Service365
New Member Welcome Area
09-26-2015 10:12 PM
Bruce B
Q5/SQ5 MKI (8R) Discussion
09-25-2015 12:11 AM
Quick Reply: TONS & TONS!! of smoke
